Show & Shine Detailing, washing, waxing, paint care, wax, etc.
engine cleaning?
Old Jul 29, 2008 | 09:39 PM
chevy cobalt 08's Avatar
engine cleaning?
I just sprayed some engine cleaner and degreaser (pyro or something) on my engine, and it didn't really seem to do anything? It's dark so I can't really see much, but I can still see it's dirty. It has like all this white crap on it. Any ideas what to use to clean the engine since this didn't work?
Old Jul 29, 2008 | 09:41 PM
Raven SS's Avatar
simple green and a high pressure washer
Old Jul 29, 2008 | 10:09 PM
Don't got a pressure washer. That's it? Just simple green? Wow. That thing cleans anything huh? I have this rim cleaner that smells and looks exactly like simple green.
Old Sep 1, 2008 | 06:26 AM
cobaltss86's Avatar
yeah that simple green is good stuff we use it at my job to clean up ink and crap u have to dilute that stuff its so strong
Old Sep 1, 2008 | 08:25 PM
Gturismo1's Avatar
When doing any kind of engine cleaning, its best to have a set of brushes (soft bristled paint brushes will work) to agitate any sort of stuck on grime. A lot of the time, the cleaners will break down most of the grease and grime, but to get it all, you have to agitate it a little bit.
I use Meguiar's APC cut 4:1, and some paint brushes to clean my engine bay. Then I just rinse away the excess with a garden hose. After that, I dress all the rubbers and plastics with 303 Aerospace Protectant, applied with a foam applicator. Does a pretty good job, I'd say
Old Sep 1, 2008 | 08:31 PM
camarokiller's Avatar
Gunk brand Engine brite.
http://www.gunk.com/
Spray it on
Let it sit for 5-10 mins
Hose it off with the garden hose
It works great!
Old Sep 1, 2008 | 08:33 PM
lewisb13's Avatar
From: Home: Utica, MI Current Location: Mobile, Alabama
Drive up to the do it yourself car wash. Now you have a pressure washer.
Old Sep 1, 2008 | 09:00 PM
Viper33884's Avatar
Problem solved LOL..
I use Purple Power.
Old Sep 1, 2008 | 09:02 PM
powerz's Avatar
we have a company here that steam cleans them for 35$ under the hood its an opening price special so ima get it done once to see how well it does
Old Sep 1, 2008 | 09:05 PM
cougar2588's Avatar
is there anything in our engine bays that we should cover before hosing it down?
Old Sep 1, 2008 | 09:07 PM
boostedss26's Avatar
gunk engine bright works great. Dont use the foaming stuff
Old Sep 1, 2008 | 09:08 PM
Jimmys2007CobaltSS/C's Avatar
yea^^^ good question i don't feel right spraying water on my engine
Old Sep 1, 2008 | 09:09 PM
Viper33884's Avatar
Not really, just don't soak it real bad. Let it dry up pretty good before starting to avoid belt slippage and wear.
Old Sep 1, 2008 | 09:10 PM
dman090's Avatar
water wont damage the engine?
Old Sep 1, 2008 | 09:11 PM
Viper33884's Avatar
Not the engine, but don't soak your filter if you have aftermarket or don't completely soak your electrical components.
Old Sep 1, 2008 | 09:29 PM
cougar2588's Avatar
yea im hesitant to give it a shot, but i have read somewhere that in newer cars as long as you dont soak everything to bad it really shouldnt hurt anything.
Old Sep 1, 2008 | 10:26 PM
Viper33884's Avatar
Exactly......
Old Sep 1, 2008 | 11:11 PM
Just look at as your engine getting wet from driving in a rain storm, same thing.
just dont soak your air filter or spray drectly into the electrical conections with the pressure washer.
Old Sep 2, 2008 | 12:20 AM
zillaguy07's Avatar
Simple Green smells like Jagermeister
Old Sep 2, 2008 | 12:28 AM
Viper33884's Avatar
But it works.
Old Sep 2, 2008 | 12:47 PM
jerrodmann's Avatar
im scared to pressure wash this engine... my G6 3.6DOHC i had to problems pressure washing it... but i guess i dont know enough about the components of this engine to do that... any thoughts?
Old Sep 2, 2008 | 01:17 PM
Viper33884's Avatar
Oh the newer the cars the more protected they are. We have been getting some heavy rains lately and it was so bad the other day my belt was slipping bad. Thank you Injen filter for not sucking water, so it goes to show you, don't put direct pressure for an extended amount of time and your good, just a quick rinse with a pressure washer or garden hose.
Old Sep 2, 2008 | 04:13 PM
zillaguy07's Avatar
But it works.
Yes it does, very well. I always used it to clena my quads after muddy woods riding... works great.
Old Oct 3, 2008 | 05:28 PM
blu3_v1p3r's Avatar
everyone keeps saying not to spray the electrical components, but if you look at the engine there are wire harnesses and electrical parts everywhere. Also it is not the same as a rain storm, because if i go lift hood when its raining my enginge is not wet. only the bottom is...
Old Oct 3, 2008 | 07:28 PM
laserblue2006's Avatar
dont just sit there and soak the fuse box and stuff like that but i have sprayed the motor and all before no harm
also i use simple green and it works beautiful
