Microfiber Drying FTW
Well for as long as ive owned my cars ive hand washed them which meant hand drying them as well. Ive used everything from my dads ancient animal hide chamois to the magical super absorbent drying towels that work so well (yah right). My favorite was the natural chamois but it had to be rung out so often it was annoying and it left fibers on the car.
So after learning from experience and talking to many others and reading uber info I slowly learned the "right way" to clean my car. And I soon found out that the "right way" involved microfiber. From cleaning to buffing its the way to go.
So finally I decided to try one of the waffle weave microfiber drying towels and WOW! I mean WOW! 1 panel done, no streaks, no lent, no swirls, and the towel hardly felt damp. I tried wringing it out several times but nothing would ever come out, it just held everything. After being very satisfied and 90% done with drying i rang it out and only got a shot glass full of water.
You can even use the corners to stick in lug nut holes and pesky areas that hold water like the bottom corners of the rear windows on these cobalts and it almost sucks the water right out.
So to any of you still using a terry cloth towel, chamois, super towel or anything else just give the microfiber waffle weave towel a try, you wont regret it.
Don't forget to tear off any wash tags on the MF/WW towels! They can cause micro-marring if you are not careful.
Autozone sells Viking products, they have some pretty good quality microfiber towels.
thanks,I using mf for detailing and the obsorber for drying,I'll give this a try.
I go over the car one body panel at a time. For each one I go over it several times (GENTLY) until it is smooth as silk and there is NO water left. Its a really great feeling once you have completely eliminated all surface particles. Very smooth.
To answer your question: Maybe not perfect, but to the naked eye it is spotless.
It all depends on what point during the drying process you use it. If you use only the MF towel to dry the whole vehicle right after washing it will eventually get water soaked and leave residual water.
The method I use when detailing vehicles is the following:
After washing I unhook any attachments and use just the open hose and completely cover the car. Reason being is when you use just the water flowing from the hose it will cause a vast majortiy of the water to sheet off the vehicle rather than spraying water from a nozzle. Once I am done with that I use an obsorber to soak up and standing water left over. I take a leaf blower with a filter screen under the blade to keep foreign objects from getting flung at the vehicle afterwards to get water out of the grilles and crevices. From there I follow up with a high quality micro fiber waffle weave to clean the rest up for a streak free and dry surface. This method sounds like a lot of work but it minimizes swirls and micromarring.
if you really want a nice shine ...ge tthe ones that have a permanent wax in them.....leaves the car lookin like it does from the first day you pick it up at the dealership( assuming they clean it...)
I personally have never liked the wax in wash type products. I personally like to wash the car and wax it separately for that nice deep finish look.
Ive been using my leaf blower since i got my car , really helps the back bumper bottom slots , side mirrors and trunk /window/door creases.
Oh and the wheels too , blows the water right out of the lug holes , and drys the tires faster so you can put your tire shine on .
Go to http://www.microfiber.org for some great prices.
