Quick Question
My 09 only has 650 Miles on it so far, and I have washed it every couple days.
I haven't done anything as far as exterior detailing goes, besides washing.
I got the 4 oz bottles of TurboWax's Paint Cleaner, Final Polish, and then Synthetic Polymer Wax/Sealant.
My question to you all is the following;
My car, being so new, doesn't have ANY swirl marks or blemishes yet.
How do I go about waxing this?
let me restate.... Do I REALLY need to use a paint cleaner...and then a polish, before applying TurboWax's "Wax/Sealant"?
Any thoughts?
I really want my baby to have some protection on the road... but I don't want to skip any prep work. But also, I don't want to do any work that is not needed ( Wish I had electric orbital buffer!_
P.S.- Stay tuned to this sub-forum for my write up on TurboWax's Car Shampoo and Tire Dressing, I will be typing it out after work tomorrow. Here is a hint- TurboWax Rox. I will elaborate tomorrow
Any thoughts?
the paint cleaner ill clean all the impurities off the paint. especially rail dust.rail dust is iron fibres kicked up from being in transit on trians.iron wheels in train grinding agianst iron rails send iron fileings allover new cars on trains on the way to dealerships. use the cleaner to get everything off and follow the steps on the bottles.if your going to spenad all that time waxing and polishing your car then dont skimp out on the small details.theresults will pay off more in the long run when you do all steps.
good luck
good luck
good luck
good luck
another members car on the site
my car
alright fiscal....you dont need to use the polish right now
but i would use the paint cleaner as they have said it removes oils and other impurites....
example:
feel your car after you wash.
then use the paint cleaner.
then feel.
it will feel smoother.
now wax and it will feel perfect.
if you want to just test it on your spoiler or something and if you think it should be done to the rest do it, and if you dont then dont do it.
example:
then feel.
example:
then feel.
example:
then feel.
I am asking for a Random Orbital Buffer ( electrical) for Christmas!
Any suggestions as far as models/makes?
Looking to keep it under 200$
I just washed my car the other day and it looks polished and ****.
like I said, I only have 650 miles on the car. There are no swirl marks or anything yet.
I had to ask on here however, because I was under the impression that polish gives you the shine, while sealant/wax just locks it in.
So laserblue...you sure I wouldn't need a polish.
Once again.. I am using TurboWax line.
Cleaner+ their wax ( its actually a synthetic tri-polymer sealant) will give me the shine?
Hell.. it shines great now with just a TurboWax Shampoo!
I am mainly just concerned with Protection.. more so then shine.
Also.. when doing this by hand... is a soft-foam applicator the best to use to actually apply cleaner/wax?
Its what I have been using... then cotton/microfiber applicators to remove/final buff dry.
Thank you for being the first person to actually address my situation here..much luv bro.
but i use a Porter Cable 7424
autogeek has a good starter kit for around 250....
i know it seems like a lot but you also get abunch of pads better backplate and some other goodies
now polish gives you that "shine" by leveling the paint...it removes the light swirls to make it look perfectly smooth...so once again if you have no swirls then no need to polish.
and yes if doing by hand then the soft foam applicator is the best. it is what the pads for a DA polisher are made of.
also microfiber is the best to remove it with...i dont know what your microfiber situation is but at sams they have some that you get 24 for $10....and they are very good.
also you are correct....good wax/sealant does zero correction it only protect your work...
but for now try using the cleaner on spoiler/trunk...then judge based on your judgement if you think it is needed for the rest of the car....
also when doing the wax follow the lines of the body....that way if you do just so happen to "scratch"(as in super fin scratch) you will only see it from a certain angle and not all angles....
i personally would not use a polish without a buffer...as you cant not create the condidtions necessary for the polish to work at it optimum point. many many times you will create fine swirls...which are not appealing
Thanks
We have a Sams Club we shop at regularly!
24 Applicators for 10$ what a deal IMO!
What is the low end-high end of pricing when it comes to electrical orbitals?
is 250$ entry level?
and 250$ is entry level but its also all you will ever need....and porter cable is a good brand and like i said that 250 is a kit with about 6-8 pads and some other helpful stuff....ill get you a link
alright well i was wrong and in a good way lol
its 199$
http://autogeek.net/hk7424.html
Last edited by laserblue2006; Sep 12, 2008 at 08:24 PM. Reason: Automerged Doublepost
