OneCOLDBIZL272 November COTM Submission
Car Info: 2005, Chevy, Cobalt, SS/sc
Stock Options: Fully loaded minus a sunroof
Exterior Modifications:
Debadged
Shorty Antenna
Painted Black Head Light Housing
Super White Led Corner Lights
Skyline Style Tail Lights Functional
Team Rev Banners
Custom Front Upper Grill
Painted Red Brake Calipers
Stock Rims Painted Black
10K H.I.D. Conversion Kit
Evo 10 Bumper Mod
Interior Modifications:
Custom Dash Inserts
Blue Led Module Kit For Dash Cluster
Three Pod Pillar (Cobalt 30psi Boost Gauge/Water Temp/Oil Pressure)
Custom Dual Cluster Pod (Aem Wideband/Empty right side as of now.
Avic-D3 In-dash Dvd/Nav
Led Interior Lights
Performance Modifications:
Pistons 10:5.1
Custom Sleeved Block
Crank Shaft Polished/Platinum Coated/Cross-Drilled/Knife-Edged/Lightened/Balanced
Built Head
Custom Ported/Polished Head
7,200 Rev Limiter
Custom Balance Shafts Delete Kit (deleted there are no balance shafts at all)
Custom A/C Delete Kit
Custom Hardened Oil Pump Gear
ARP Head Studs
ARP Main Studs
Cometic LSJ MLS Head Gasket
Spec Flywheel
Spec Stage 3+ Clutch
GM Stage 2 Belt
ZZP Adjustable Tensioner
Custom Ported Intake Manifold
Custom Ported Supercharger
Coolingmist Meth/Injection Kit
2.7 Pulley
Custom Stage 2 Hub
Supercharger Coupler
Custom 3" Intake
3.5” Throttle Body off GM 4.2L thaoe
Custom 3" Under Axle Exhaust System
JBP Vortext Header
OTTP Second Gen Heat Exchanger
Meziere's Aftercooler Pump Custom Mounted
Dual Pass Endplate
HKS Oil Catch Can
Fuel Filter
Walbro 255 Fuel Pump
60LB Injectors W/Harness
NGK Spark Plugs(Same As Time Attack Cobalt)
NS-ll Performance Tires Drag Radials
Stage 2 Axles
Tenzo-R Lowering Springs
Turbo Tech Racing Rear Sway Bar
Drilled & Slotted Rotors/Ceramic Pads
Trans Mount Bushings/Custom Shims
Upper Billet Engine Mount
Polyurethane Control Arm Bushings/Custom Shims
Custom Solid Driver Motor Mount
Custom Tune Hp/Tuners
Painted Supercharger/Intake Manifold And Whole Motor(Black W/Some Red Accents
Future plans:SS/TC shocks and struts,SS/TC Seats, Carbon Fiber hood and trunk and spoiler
Other info:Team Rev Car Club Owner, All work on My Car Was Done Mostly By My Wife & I, And My Good Friend Curt.
Thanks For Looking and too everyone that votes for me! And good luck to everyone in the running.
If anyone cant see my pics click on the camera under my name where is say the number of post i have thanks
P.S. my b-day is November 28th and what would be a better early b-day gift as being car of the month woot woot ....happy voting everyone
Debadged
Shorty Antenna
Team Rev Banners
Evo 10 Bumper Mod
Custom Dash Inserts
Led Interior Lights
Pistons 10:5.1
Built Head
7,200 Rev Limiter
ARP Head Studs
ARP Main Studs
Spec Flywheel
GM Stage 2 Belt
2.7 Pulley
Custom Stage 2 Hub
Custom 3" Intake
JBP Vortext Header
Dual Pass Endplate
HKS Oil Catch Can
Fuel Filter
Stage 2 Axles
Oh **** its the other silver balt at the midwest meet. Whats up dude? Nice ride, you have a long list of **** done man! Nice!
GL!
Might have to have you port my sc when we have our t4b-tr meet this summer.
Also take some interior shots to show how pretty it is.
GL!
Bump^
i was going to have me lic plates change to GR8 Whte at one point, there other pics to and i was going to use the pics as a sig but just never did i got different plate which came in today Lil Vett
I will take some pic after winter, cars in storage already, but i will for sure
bump^
bump^
Last edited by OneCOLDBIZL272; Oct 27, 2008 at 07:04 PM. Reason: Automerged Doublepost
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
