upgrade the power steering.
Old Mar 3, 2010 | 08:49 AM
biggiesize's Avatar
Im all for the recall on the Cobalt power steering.It has been a long time coming,but the question that I cant seem to find an answer too is this:How will GM improve on the new powers steering motor?A recall is great,but if they dont improve the P.O.S electric motor on the steering column,this problem will happen over and over again.ALL electric parts eventually wear out and I can see how any fix would be permenant unless they change it out to the old tried and proven power steering pump.It just seems like a band-aid on an artery wound to recall all these cars only to put the same failing part on them for another 20-30,000 miles.
Old Mar 3, 2010 | 09:02 AM
blackbird's Avatar
Regular hydraulic power steering pumps fail all the time too. Same thing with leaky steering racks and numerous other issues as cars get older.
Will this recall permanently solve and prevent all future power steering issues for every Cobalt owner? I doubt it and I also don't expect it either. It's an inexpensive economy car and although they may last 500,000 miles they aren't designed to. Same thing with $75k luxury cars. Everything has a service life to include the stock electrically assisted power steering.
Overall it has many advantages over a conventional system with less potential points of failure. If GM has properly researched what was causing the premature failures and issues then this recall should be very effective. We don't even know yet what the extent of repairs will be, but at least they are doing something and not shafting Cobalt owners with expensive repair bills when out of warranty.
Old Mar 3, 2010 | 09:10 AM
PRND3L's Avatar
you also need to understand, GM probably doesnt make the motors, a vendor does. You car was built with parts from the lowest bidder, thats why **** fails.
Old Mar 3, 2010 | 09:25 AM
blackbolt89's Avatar
i think GM uses Delphi power steering motors. not sure though.
so yeah technically it isn't GM's fault.
Last edited by blackbolt89; Mar 3, 2010 at 09:25 AM. Reason: Automerged Doublepost
Old Mar 3, 2010 | 09:34 AM
biggiesize's Avatar
I know that JTEKT Corporation makes the power steering motor for The Cobalt.I just hope that they have some sort of an upgrade.I have a friend that has put 3 power steering motors in his cobalt under warranty.The second one went out after only 6,000 miles.
Old Mar 3, 2010 | 09:38 AM
derp. youre right. i thought it was delphi.
Old Mar 3, 2010 | 09:50 AM
biggiesize's Avatar
Delphi makes those body control modules that are giving alot of problems.They are mounted down in the passenger side floorboard on the console.I think when those go out the car dies,every light on the console blinks.Pretty much acts like the thing is gonna blow.
Old Mar 3, 2010 | 11:36 AM
qwikredline's Avatar
column brushed motor and controller integrated in cobalt seperate controller and brushless motor in HHR, KYB make it...that is all
Old Mar 3, 2010 | 11:59 AM
06yellowburdSS's Avatar
Question...should a cobalt owner who is not experiencing these defects in the power steering still take it in to get it replaced as a precaution? Or will GM dealerships not work on the car unless you have this problem? I ask because the way i interpreted the recall is that any owner can bring it in to get replaced if out of the factory warrantee range
Old Mar 3, 2010 | 12:09 PM
northvibe's Avatar
its a recall so if you get the letter, take it in. Only like a TSB is it only if you get the problem, recall is you take it in no matter what.
Old Mar 3, 2010 | 12:12 PM
do you think they'd fix that gnarly column rattle too if i ask them to?
that **** gets so annoying.
Old Mar 3, 2010 | 02:07 PM
hockeylx92's Avatar
serioulsy...***** so annoying
Old Mar 3, 2010 | 02:19 PM
northvibe's Avatar
I dunno what noise that is...mine only has 7k so I dont have any noises.. MY moms 05 malibu has a steering clunk as well (and thats drive by wire) which is a very common gm issue I guess...that sucks.
Old Mar 3, 2010 | 02:22 PM
prolly sway bar end links malibu, monte carlo impala they all suffer from it
Old Mar 3, 2010 | 02:23 PM
the whole steering column internally rattles. you can hear/feel it.
don't worry you'll get the infamous rattle sooner or later.
Old Mar 3, 2010 | 02:26 PM
jlong3382's Avatar
Simple......they'll upgrade the motor to a better one
Old Mar 3, 2010 | 07:21 PM
biggiesize's Avatar
that rattle you are talking about is the rack and pinion.It does it over bumps or just simply driving.Sounds like somethings gonna fall apart.I have a personal friend that works at the GM stealership here who I know wouldnt do me wrong.He told me that the rack and pinion gets a small amount of play internally.He says that it is not going to fail or harm anything as long as I can put up with the rattle/knocking.Apparently all Cobalts are going to do it at some point.
Old Mar 5, 2010 | 05:45 PM
Ridinonrails's Avatar
Umm....GM now owns Delphi since the bailout.........
Old Mar 5, 2010 | 10:06 PM
post 8 KYB...
Old Mar 7, 2010 | 06:59 PM
Blue_Balt's Avatar
I had my power steering motor replaced 2 years ago and I haven't had a problem since.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
HEATON
Oct 16, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
Stuff
Oct 1, 2015 05:47 PM
