Help! Parts identification
Old Oct 14, 2017 | 09:08 PM
X-star's Avatar
Just went to look at a 2010 SS/TC everything on it is good except I have some concerns. Look at the turbo what is it? it is not stock.
ialso have two of these air bypass valve solenoids. The one on the front left of the motor is hooked up. The one on the passenger side rear is plugged in but no vacuum lines are hooked to it. Can somebody tell me what vacuum lines connect to it. I didn't see any extras that may belong to it.
One last thing. This connector was in the trunk. Any suggestions to what it is.
Old Oct 14, 2017 | 10:08 PM
X-star's Avatar
One more thing. I would not make more than 6-7 lbs. of boost.
Old Oct 14, 2017 | 10:56 PM
Turbo looks stock, it seems like you have a forge bpv on it. You should only have a solenoid and should be mounted on the intake manifold
Looking at the picture it seems like they connected the bpv solenoid to that connector and shouldn't have that connector should go to the turbo
Old Oct 14, 2017 | 11:59 PM
X-star's Avatar
I will look at it in the morning. You are saying that I should only have the one mounted to thi intake. Not a second one in the rear by the coils. Correct?
Old Oct 15, 2017 | 01:01 AM
Intake manifold not the intake and no you shouldn't
Old Oct 15, 2017 | 09:43 AM
X-star's Avatar
is this why it's not putting out more than 6-7 pounds of boost? Leave it on or take it off and put back to factory?
Old Oct 15, 2017 | 10:09 AM
cw383's Avatar
I don't remember who originally made this diagram, but you should find it helpful.
Old Oct 15, 2017 | 12:20 PM
X-star's Avatar
that one is correct. I have another one that's not suppose to be there. I am looking into it now.
Old Oct 15, 2017 | 03:56 PM
exninja's Avatar
The last part is a knock sensor
Old Oct 15, 2017 | 05:54 PM
X-star's Avatar
So I plugged that connector into the turbo, now no boost and won't wind up more than 3k RPM. There was nothing plugged into the turbo so that connector plugged right in. I will unplug it for now. Any suggestions? Not sure what the problem is.
Old Oct 15, 2017 | 06:15 PM
cobaltssdude420's Avatar
Apparently the vacuum tank those hoses go to is useless. Words from my tuner...
Old Oct 15, 2017 | 07:23 PM
exninja's Avatar
My guess is something is wrong with the waste gate solenoid and the previous owner tricked the computer by putting a bypass solenoid on the connector.
Old Oct 15, 2017 | 07:49 PM
X-star's Avatar
that is what I was thinking. Just trying to get it right.
Old Oct 15, 2017 | 08:19 PM
Yeah I'm thinking the same thing as exninja
Old Oct 15, 2017 | 08:24 PM
X-star's Avatar
What are your thoughts on the BPV leave it on or replace with factory part?
Old Oct 15, 2017 | 08:43 PM
Well I would fix it for sure, having 6 psi of boost isn't really any fun
