had a clunk for a while, had to replace the sway bar end links. now it has the normal dash slamming, but less front suspension clunk. it probably needs all new suspension stuff and probably steering too.
https://photos.app.goo.gl/1xF8rfHhyOo1CZgy1
Had a ton of front end work done
ZZP front red Cobalt sway bar & bushings
#93-New ZZP fuel filter for LSJ
#94-ZZP LSJ stage 1 axels driver & passenger
#95-Redline manual M-90 tranny fluid 3qrts
#96-New inner tie rod ends driver & passenger
#97-Cooper Zion rs3 G1 tires 4 all season
#98-New driver side control arm & ball bearing
#99-Year worth of free alignments
#100-TD road hazard warranty on all 4 tires
Your ride is always super clean Doug. Great work!
I just purchased the first few parts of my suspension, all FE5: Moog problem solver endlinks, AC Delco rear springs, and a new intermediate shaft. When I get paid again, I'll be buying the pre-assembled moog struts.
Now I just have to wait another month so the weather gets back to above freezing.
Thanks profDNS! Just like the rest of us I certainly put a lot of time & $ into my build so it's always nice to get a compliment from a fellow modder! You're gonna be happy with those Moog end-links stops that front end noise for sure!
Thanks snail! Juan must have shipped our packages at the same time lol. You'll have to post some pics after you get your headlight covers installed! & your right they aren't cheap so it's not hard to run out of $ before getting the complete set. I'm just waiting on Juan to cut me a fuel rail cover & door sills & I'll have the complete set!
Well what do you know guys as if dropping $1500 on my car last week wasn't enough I just went & put another $760 in her this week!
New Car Quest starter with lifetime warranty
New Auto Craft Gold battery 650 cold starting amps 3 year warranty then prorated after that
New Moog problem Solver sway bar end links both driver & passenger side with lifetime warranty
Also installed the rest of my covers from Juan
I always wondered if the coil cover that's on the lsj and Saab 2.0 is detrimental to the life of the coils. Lnfs didn't have one and I hear way less about their coils failing. Wonder if the lsj coils get too hot under there. Looks really nice Doug.
Thanks Nova & good call about the coil cover. I've been fortunate & haven't had any issues. My OEM never acted up & then I installed the Zzp high voltage packs a couple years ago & they have been great as well.
On the right side there's an opening to let fresh air in but it's nothing like having the cover off.
