2.4L LE5 Performance Tech 16 valve 171 hp EcoTec with 163 lb-ft of torque
2.4L LE5 Internals HELP!!!!
Old Apr 10, 2018 | 12:03 AM
Larrayjayy96's Avatar
Hey guys Im new to this site and I have searched and searched for internals for the LE5 and I am at my wits end trying to find anything other than pistons. I know in my model it has forged internals but im just looking for a website, catalog or something in case I ever needed anything in that sort. I would appreciate it if someone can please point me in the right direction that would be great.. TIA
Old Apr 10, 2018 | 08:21 AM
Molnar makes rods for the le5 and zzperformance stocks some pistons for it. Otherwise you can just call diamond or wiseco and theyll have a set made up.
Old Apr 10, 2018 | 10:46 AM
Henry3959's Avatar
The 2.4 is a bit of a step child in the cobalt world but if your pre-08 you have good components to start with. Knowing your end numbers would help. Some are going to 300HP with stock internals and did for a while.
Stock crank, Molnar rods and Diamond pistons will make for a better bottom end than the block can handle.
Old Apr 10, 2018 | 10:53 AM
chevygirl2006's Avatar
They don’t have forged internals. They have semi forged rods. Can’t really call them forged. And molnar and diamond to answer your question
Old Apr 10, 2018 | 02:06 PM
There is no such thing as “semi-forging”....
Old Apr 10, 2018 | 02:44 PM
DFZ24's Avatar
now quick question, so the OP doesn't encounter problems.
Does molnar rods are compatible with diamonds pistons? or wiseco piston?
If I recall correctly, there was an issue where a brand would not be compatible with another brand. So you have to get all in one. I might be mistaken but I think it was zzp rods or pistons?
Old Apr 10, 2018 | 02:57 PM
I have molnar rods with diamond pistons.
I think the issue is using stock pistons and aftermarket rods. The factory small rod end is tapered vertically and aftermarket rods are square.
Old Apr 10, 2018 | 03:07 PM
I also am using molnar and diamond
Old Apr 10, 2018 | 03:13 PM
Henry3959's Avatar
https://youtu.be/Kt74B72Faz8
Fractured / Sintered powdered metal rods were the 08 and forward from my understanding. Yamaha started this in 03. They are a net manufactured rod which is why they don't have grind marks. Not nearly as good as the pre-08 forged rods.
Old Apr 10, 2018 | 03:16 PM
the forged rods in 06-07 are powdered metal forged. 08+ are just powder metal cast
Old Apr 10, 2018 | 03:29 PM
Henry3959's Avatar
From the Sportsman Ecotec Race Engine Book.
The 2.0L LSJ and LNF ECOTEC engines have forged steel rods similar to Small Block Chevy “Pink Rod.” The forged steel rods are made of high quality material and have a cap screw, 23 mm small end, and a full floating bronze bushing. These rods are available through GM service parts. These rods require an aftermarket piston set to work with the stock 2.2L crankshaft. Alternatively, Eagle and Manley both offer a CNC machined H-Beam rod which is an exact replacement for the stock 2.2L rod. (Fig. 8)
Old Apr 10, 2018 | 04:34 PM
DFZ24's Avatar
Do you have any idea if molnar rods will work with wiseco pistons?
Old Apr 10, 2018 | 05:28 PM
https://www.youtube.com/watch?v=O7U4HWjYcqo
This has nothing to do with le5 rods.
Old Apr 10, 2018 | 05:29 PM
I think that they would, but you can ask wiseco.
Old Apr 10, 2018 | 05:40 PM
Henry3959's Avatar
Didn't say it did....
Old Apr 10, 2018 | 05:52 PM
Did you not take the time to watch the 27 second video that I posted that explains what PM forging is?
Old Apr 10, 2018 | 05:55 PM
Henry3959's Avatar
I know what it is. I was with GM when they started doing it and boasted it as the next best thing.
The video I posted covers the most important process of Sintering the component
Old Apr 11, 2018 | 12:34 PM
I have a 2007 Pontiac G5 GT 2.4L. i came to this forum because the G5 forum doesnt get into explanation like this forum does.. if I were to SC my car other than the kit ZZP provides for the 2.2/2.4 what would I need and how much boost can this car handle with a stock bottom end?
Old Apr 11, 2018 | 12:37 PM
Old Apr 11, 2018 | 02:35 PM
Boost isn’t power. More psi doesn’t mean more power. There’s been stock 2.4s over 400hp
Old Apr 11, 2018 | 02:48 PM
Stock le5 will handle anything an m62 would throw at it.
Old Apr 11, 2018 | 03:10 PM
I never said boost was power? What do you mean stock over 400hp? There has to be something done to it to push 400hp lol
Old Apr 11, 2018 | 03:13 PM
But anyway basically your saying I dont have to touch the motor at all? Thats great when your budgeting lol.
Old Apr 11, 2018 | 03:52 PM
You said how much psi can it handle. Psi is not power. There’s no “psi number” that will blow your motor. It based off of horsepower and torque. And stock 2.4 motors have been over 400
You would think but not always
