Interior: Shifter Knob Removal & Factory Quality Replace w/Any Knob
Old May 13, 2006 | 10:16 PM
BlilBT's Avatar
1st)Pop Cap On Shifter Knob & Remove Screw
2nd) PULL LIKE HELL
3rd) Pull straight back on dash end of boot, so it unlaches
4th)Slide Whole Boot & Reverse Lock out off Shifter Shaft
5th)Not needed but recomended, The Shaft on the Shifter is dull & dirty. To get it to shine Use Steel wool (FINE COURSE) or compatible with some metal polish. Will make it look really good if u take your time. (Some of the Shaft will show When you are done)
6th)Invert Boot Cut Zip Tie that Holds Boot on Reverse lock out. (Dont worry Leather wont Fall Apart,But make Sure to cut Zip Tie ONLY.)
7th) Cut Reverse Lock out just under Finger Grip & Flush with the top of the Boot. You Can use a Hacksaw or Power saw. (just make sure to REMOVE BOOT before you cut.
8th) Now Take The Leather off the Old Shifter Knob By Cutting The Stich then removing the leather.
9th) Cut a piece of Leather about half the lenght of wat you removed from Knob.
10th) Wrap Cut Leather over end of Reverse Lock out Where you cut it & Zip Tie in Place as Seen in pictures Red Zip tie.
11th) Now Place Boot over Top of Reverse Lock out (Note boot will Be inverted as seen in Pictures) Now Zip tie in place Black zip tie in Photos. Black Zip Tie Replaces one You cut in Beginning.
12) Reinvert your Boot & & Ready for Install, Cut the hole in the top of the Leather smaller than the Shaft so that it fits tight around the Shifter shaft (NOW YOU R READY FOR ANY SHIFTER KNOB YOU WANT & YOUR REVERSE LOCK OUT STILLS WORKS & IT LOOKS LIKE A FACTORY DID IT)
I Know it sounds Hard it is Really not & the Results look like Factory & U can put wat ever you want on.
By the way the Reverse Lock Out still works By Grabbing the Boot, Like In Picture.
(SPECIAL NOTE IS... LET YOUR FRIENDS OR ANY 1 FIGURE OUT HOW TO PUT IT REVERSE)
( Sorry for the Book)
Attached Thumbnails hpim1112.jpg   hpim1114.jpg   hpim1116.jpg   hpim1118.jpg   hpim1108.jpg
Old May 18, 2006 | 02:26 AM
05BlackCobaltSS's Avatar
now that's sweet!
Old May 18, 2006 | 01:37 PM
silverSS's Avatar
i guess the yellow matches your car/seats
but it looks tacky to me
Old May 18, 2006 | 01:39 PM
plyboy-illest's Avatar
nice write up!
Old May 18, 2006 | 06:14 PM
BlilBT's Avatar
Wasnt writting it up for opinions , Wrote it up to show how to put any KNOB u WANT on & how to Keep the reverse lock out working
Old May 18, 2006 | 06:17 PM
BlilBT's Avatar
nice write up!
Thanks Man seen lot of peps Having Problems with it . Thought i would show them how to use wats there & match the leather on the boot . Secound off you need the reverse lockout to keep gear shifter track aligned,,,other y's you over shift going into 5 gear.
Old Jun 8, 2006 | 09:08 PM
BlilBT's Avatar
BooSSted hope you read this it will help you.
Old Jan 29, 2007 | 10:34 PM
RedSSBaltSC's Avatar
hmmm
Old Jan 30, 2007 | 04:25 AM
TheFordGuy's Avatar
Looks like a rubber ducky! Cool mod either way.
Old Jan 30, 2007 | 12:54 PM
Xavipheus's Avatar
is that an automatic?
Old Jan 30, 2007 | 04:23 PM
BlilBT's Avatar
NO Its a SS/SC Here is the New Knob!
Old Jan 30, 2007 | 04:26 PM
rickyw's Avatar
do you have to worry about it slipping off?
Old Jan 30, 2007 | 04:38 PM
BlilBT's Avatar
I've had this Mod for awhile Now & Had No Problems what so ever! Actually on My 2nd Momo Shift Knob! The 1 in the How-to Sucked ass!
Old Jun 7, 2007 | 02:57 PM
blue06's Avatar
2nd) PULL LIKE HELL
Worked out great thanks for the HOw to do
Old Jun 7, 2007 | 09:35 PM
YellowG5's Avatar
Still Like to know how to get the shifter off in the cars WITHOUT the Reverse lock out...
I tried getting the cap off, didn't work.
Tried getting the boot to slide down off the knob, Didn't work...
What else is there?
Old Jun 8, 2007 | 08:41 AM
BlilBT's Avatar
What else is there?
The cap on our cars was a snap in. Not sure on yours, Should be the same! You have to remove the silver cap to remove the screw to remove shifter Knob To remove the boot!
Old Jun 10, 2007 | 10:24 AM
YellowG5's Avatar
Well, I don't want to damage it, but okay, I'll try
Old Jun 10, 2007 | 05:12 PM
blue06's Avatar
you need to pull the black trim around the silver cap also that's what I did. The knob is the hard part. I used a hammer on the bottom side of the shift knob, don't do hard, real gentle knocks on the bottom. It'll eventually come off
Old Jun 10, 2007 | 08:00 PM
BlilBT's Avatar
I Pulled Like Hell & wobbled it a Little & it came off! It should not damge anything!
Old Jun 20, 2007 | 12:49 PM
marerick007's Avatar
Mmmm, might have to try this whenever I find a knob I like!
Old Jun 20, 2007 | 12:52 PM
Psykostevo's Avatar
That's what I was looking for. Thanks for the istructions!
Old Jun 20, 2007 | 09:33 PM
BlilBT's Avatar
No Problem, If you have any Problems let me Know I'll help ya any way I can!
All in All it's easy!
Old Jun 24, 2007 | 12:52 AM
snobrdrdan's Avatar
Where'd you get the Momo knob from?
AND what holds it to the stock shifter??
I haven't taken my stock knob off, but does the stock or Momo thread on or what??
Old Jun 24, 2007 | 09:04 AM
BlilBT's Avatar
MOMOUSA.com Or Motorsportsmarketing.com & It has set screws that hold it!
Old Jul 7, 2007 | 04:13 PM
jimbos'ss's Avatar
what didi you do with the spring that goes on top of the reverse lock out, leave it off?
