For Sale new garage cleanout thread
Old Oct 19, 2015 | 07:46 AM
06blackg85ss's Avatar
and here we go: (have some more pics with my screen name and date I'll upload a bit later. Can't use photobucket from work)
well here we start with the screen name stuff
all painted up nice. looking for $275 shipped
here is a pic of all the heat exchangers intalled on the car
zzp stealth on its own
(those red blocks are the temp sensor locations for the aem gauges)
this is the setup now, so no need for the sc stuff hence the sale
Old Oct 19, 2015 | 07:47 AM
2.55 zzp pulley
a bunch of stage II gm pullies
a 2.85 pulley for a stage II hub
I have a stock clutch with about 38k miles on
a spec stage II but that needs a new disc w/fidenza flywheel that needs a new wear ring. Pressure plate has some heat marks as my slave went out and I drove the car for about 1.5 months with no clutch (so much fun in NYC) but it's in decent shape, flywheel took most of the beating on that
random stock brake parts with some decent miles on them
have 3 lsd diffs from g85 trans, 2 in great shape but will need new final drive gears as both have chipped teeth (1 is still in a trans but I could pull it, might have a bit of surface rust but still functional)
looking for $250 + shipping for each of those
have some cooling stuff left over,
also have a stage IV ctsv front mount. does require some cutting to make it fit, but it holds over a gallon of coolant and does quite a good job at getting rid of heat
ZZP stealth he $250 + shipping
2 AEM digital coolant temp gauges that read from 0-150 that I used on the inlet and outlet of the intake manifold to see temp rise and make sure system was functioning properly.
still have a bunch of honda parts for a k20 crx swap if anyone knows anyone looking for that.
5 speed trans axles charge harness and shifter box
also have some fd rx-7 parts I need to get rid of too. 99 spec turbo's for non sequential use, cusco strut bar, stock 93 computer, driver side JDM spec tail light (round lights) etc
have some LS parts also (as in lsx) 5.3 heads, truck intake mani w/injectors and rails, stock f-body fans
stock 98 computer w/engine harness
header back up for sale
$275 shipped
link for new
http://www.summitracing.com/parts/vp...FYOPHwod7QEN_A
Old Oct 19, 2015 | 07:49 AM
all the cooling stuff from my s/c setup is up for grabs, also have 2 cryo 2 kits complete not installed. dual pass endplate. 2 s/c intake manifolds etc
Old Oct 20, 2015 | 05:48 AM
richsoucie's Avatar
Do you have driver side bracket for stock h/e
Old Oct 20, 2015 | 07:13 AM
Staged07SS's Avatar
Administrator
Administrator
Please get the updated photos with your user name and current date up asap.
Thank you.
Old Oct 20, 2015 | 07:59 AM
it's still in use holding the ac condensor
Old Oct 20, 2015 | 08:00 AM
Thank you.
working on it.
and the exhaust is when I did it, as you can see busy and just now had time to post it.
Old Oct 20, 2015 | 08:27 AM
is the derale cooler for sale
Old Oct 20, 2015 | 01:34 PM
yup that is too, just gotta see what the cost was on it. should have a price up tomorrow.
Old Oct 21, 2015 | 12:23 AM
Italoumiami's Avatar
Is the intake fs?
Old Oct 21, 2015 | 07:37 AM
which intake?
Old Oct 23, 2015 | 05:26 PM
CynicalCitizen's Avatar
How much for the s/c intake manifold? And what would you charge to ship them/ the header to Canada?
Old Oct 26, 2015 | 04:22 AM
zdohare's Avatar
I need a good stock clutch and flywheel, sounds like you got me half covered. Pressure plate and disc?
Old Oct 26, 2015 | 10:49 AM
I'll check condition tonight or tomorrow.
and not shipping to canada sorry
Old Oct 27, 2015 | 08:11 AM
TheRage's Avatar
Pm'd you about the cryo2 kits.
Old Oct 27, 2015 | 10:28 AM
got it, let you know shortly
Old Oct 27, 2015 | 11:05 AM
hey you do need to update every thing you are selling with proper pictures; this includes the ones from your previous thread. They all need current dates.
I will need to lock if not fixed by tomorrow.
Thanks
Old Oct 27, 2015 | 11:40 AM
working on it, won't have time until the weekend though. was at the track all last weekend didn't get a chance. you can lock the older thread. I"ll just update through this one.
Old Oct 27, 2015 | 01:19 PM
Sorry, will have to just lock this one for now. Send me a message when you have pics - if you want, just include the pics in the message, and i will add them directly to this thread and reopen.
I know you have what you have... but rules.
calo247
Feb 11, 2016 07:41 PM
riceburner
Oct 28, 2015 10:13 AM
Italoumiami
Oct 18, 2015 10:46 PM
Tupp
Oct 17, 2015 08:27 PM
