Power lag/misfire in 2nd gear
Hello all. This is my first posting. I recently bought a 2007 lsj cobalt ss. It is a project car that runs and drives sorta. I have replaced the sway bar link, and wheel bearing. I know that it needs a serpentine belt, slave cylinder, axle seal. I am having a big power loss/misfire in 2nd gear and only 2nd gear. Whether I downshift into it, or shift into 2nd. It will lag/misfire and you can hear it as well. I changed the spark plugs recently and the downpipe(due to a very large hole in it). What else could be the cause?
CEL? and yes it has power in all other gears like it normally would, but I get a lag/surge/misfire in 2nd gear and 2nd gear only, and it wont be there if I shift in high rpm from first or if I slowly accelerate to past 3000rpm. It goes away after about 3000-3500rpm
Check Engine Light is what I meant. I honestly don't know. This is far out there but would it be possible for the knock sensor to pick up some sort of vibration from the transmission and pull the timing enough to cause that? Just a wild guess honestly. Hopefully someone else has experienced this and can help you with it.
Before I put on my o2 sensor(I ran without one for a couple weeks) the 3 codes were coolant sensor, misfire and emissions. Then I put the o2 sensor in and the misfire and emissions went away. The only code now is that coolant sensor one, and I can get it cleared and it will be off for a day or 2 and then it comes back, same code
BWentz
10-19-2013 09:41 AM
SpartacusXElite
08-17-2011 07:18 AM
