Take apart tail lights?
Old Feb 16, 2011 | 10:19 PM
SS_NH's Avatar
Has anyone taken apart these tail lights?
We've tried everything and haven't got it to budge yet...
Any help is appreciated.
Old Feb 16, 2011 | 11:08 PM
hook's Avatar
To the top
Old Feb 16, 2011 | 11:25 PM
Nighthawk243's Avatar
Are they broken? Anyways, I'd imagine they're cemented together which will require cutting.
Old Feb 16, 2011 | 11:29 PM
SS_NH's Avatar
there's three leds burnt out.
fackkk.
Old Feb 17, 2011 | 09:46 AM
hook's Avatar
I think it can be cut easy enough. Just wanted to see if there was a better way.
After cutting should we use cement to put it back together? Or something else?
Old Oct 8, 2012 | 01:02 AM
serega12's Avatar
So how did this go? I'm trying to take apart my stock housings and a set of IPCWs with no results. Tried baking them - nothing... Will again tomorrow or something.
Old Apr 27, 2017 | 03:52 AM
serega12's Avatar
Still no answer all these years later?
Old Apr 27, 2017 | 11:09 AM
colodude18's Avatar
OK, taillight guy here
I have probably taken apart 20+ sets of OEM tails and 100+ sets of K2 after market tails in the past 5 years.
Stock tails:
Heat them up in the oven at 180F for 10-15 minutes.
Using a small screw driver, start digging out the sealant. Heat will not liquify it but it will make it softer. Try to get underneath the sealant and you should be able to pull it out in small chunks. Be careful not to scratch up the edge of the lens or crack it while scraping; keep the screw driver close to the housing instead. Once all the sealant is out, carefully pull the lens off the housing. Don't force it.
K2 Motor after market tails.
These DO NOT come apart in one piece. If you want to modify them you will need two sets. Using a dremel, cut away the lens on one set, and cut away the housing on the other set. Then heat up the lenses and housings in the oven at 180F for 15 minutes. This will allow you to pull off the remnants along with the sealant using pliers. I included some pictures below. Just make sure to go slow and use the dremel carefully. Also, don't break off any clips or pins (especially on the inners) or you're screwed and will write off a taillight set...
Old Apr 27, 2017 | 12:13 PM
And that's why his tail lights are the best ^^^
Old Apr 27, 2017 | 03:16 PM
Adrian does your wife know you're using the kitchen counter for your tail lights?
Old Apr 27, 2017 | 03:41 PM
colodude18's Avatar
Shh only on Saturdays when she's at work
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
z28addiction
Sep 28, 2015 12:03 AM
