Changing Wheels
Old 01-15-2018, 07:44 PM
Jbsmusic1's Avatar
Changing Wheels
I have a 2009 Cobalt SS sedan and I am thinking of upgrading wheels. I know the lug pattern is 5x110 and I plan to run 18" wheels. Any suggestions on what wheels will work with the Brembo brakes?
Old 01-16-2018, 08:26 AM
hawkssoccer11's Avatar
check out the wheel thread on here. i have some msr wheels and i use a 3mm up front to clear the brembos. depends what the offset is for the wheels. 5x110 is limited to what you can find.
Old 01-16-2018, 09:31 AM
royce777's Avatar
there are actually more options than most ppl think. Typical wheel of choice for cobalt owners ins Varrstoens.
Old 01-16-2018, 10:19 AM
I like my enkei m52 wheels
Old 01-16-2018, 10:30 AM
double clutch's Avatar
Do they custom drill? I want es2s but would rather just get them in 5x110 than hub swap
Old 01-16-2018, 01:03 PM
royce777's Avatar
they did back when I had my set in like 2014-15
Old 01-16-2018, 06:20 PM
63 Nova SS's Avatar
Love mine also! Wish I had another set so I could also have a black set.
Old 04-30-2018, 10:35 AM
Jbsmusic1's Avatar
Update
I decided to go with ESR S02 custom drilled.
Old 04-30-2018, 11:07 AM
Did you contact them to have them redrilled?
Old 04-30-2018, 07:32 PM
Jbsmusic1's Avatar
No I was actually fortunate enough to get these from a guy who had them done professionally drilled.
Old 05-01-2018, 02:07 PM
Jbsmusic1's Avatar
Sneak peek
Planning to run Pirelli 235/40/18
Old 05-01-2018, 02:22 PM
royce777's Avatar
The wheels are facing backwards....
Old 05-01-2018, 03:16 PM
Jbsmusic1's Avatar
I just set them there to get an idea of how it will look lol. These wheels only go one way also thanks!
Old 05-01-2018, 05:00 PM
ProfDNS's Avatar
I've personally never liked the studded look for rims, but if you like them, it's your car!
Old 05-31-2018, 05:52 AM
Jbsmusic1's Avatar
Update
So after getting the tires mounted on the wheels attempted to mount the wheels to the car and guess what brembos do not clear in the front life sucks.
Old 05-31-2018, 07:11 AM
tomss's Avatar
I actually like the stock rims better.
Old 05-31-2018, 08:02 AM
did you use a spacer?
Old 05-31-2018, 08:21 AM
royce777's Avatar
Not sure on your budget, but I have the real wheels that these knocks off replicate. Clean brembos no problem
Old 05-31-2018, 09:19 AM
Jbsmusic1's Avatar
Update
I did not try using a spacer, also I went with 235 40-18 Federal 595 tires. The wheels are 18x8.5 +30. What size spacer do I need to be able to clear the brembos?
Old 05-31-2018, 09:20 AM
Jbsmusic1's Avatar
I'm keeping my stock wheels as well just wanted to switch up for something different.
Old 05-31-2018, 09:24 AM
I think you need a +40 offset for them to clear brembos
Old 05-31-2018, 09:43 AM
Jbsmusic1's Avatar
So would running 10mm hub centric spacers cause any issues?
Old 05-31-2018, 09:47 AM
royce777's Avatar
you will need extended studs. Not recommended to run over a 3mm on stock studs.
Old 06-06-2018, 09:17 PM
Jbsmusic1's Avatar
Fender Flares?
Has anyone installed fender flares on a cobalt ss tc sedan?
Old 06-07-2018, 08:27 AM
try a 5mm spacer first and see how well that works out for you. if not youll have to run extended lugs
user 72239
11-12-2014 02:47 PM
{TEAM ADRENALINE}
Wheels and Tires
114
11-29-2011 02:27 AM
Harvurd
Wheels and Tires
09-01-2010 11:58 PM
retrop
Wheels and Tires
04-25-2007 09:28 PM
arsenal21
10-12-2005 06:11 PM
Quick Reply: Changing Wheels
