Gmpp clutch kit
Old 02-23-2018, 03:16 PM
Scooby04's Avatar
Gmpp clutch kit
I currently have a clutch master clutch stage 3 and a lightweight flywheel, but I'm in need of a need clutch and I'll also replace the flywheel with a stock one. I know the gmpp clutch kit will work on my lnf and I'll need new lnf flywheel bolts, but will it hold full boost 20+ psi even in first gear? I'm on the stock turbo. Any input would be great or of any recommended clutch kits along with your review/prior experience with the kit.
Old 02-23-2018, 03:29 PM
cw383's Avatar
GMPP clutch is more then capable. Shouldn't have and issue till you get in mid 350hp range in the worst case scenario.
Old 02-23-2018, 04:01 PM
Scooby04's Avatar
350 to the crank or whp? Wouldn't it be depending on how much torque it's being put down?
Old 02-23-2018, 04:05 PM
It will hold just fine. It holds my 26psi (24psi for you sea level folks) and before when it spiked it held just fine then.
Also it's not going to slip in 1st gear, it would be more likely to slip in 4th (more load on the clutch face)
Old 02-24-2018, 01:13 AM
cw383's Avatar
Well mine finally found its limit on my new engine. The old engine was 432/390 torque and it held just fine. New engine is most likely near 500/500, but it hasnt been dyno'd yet. As Ecaulk stated, mine started to slip in 4th on new engine. New clutch this spring!
Old 02-24-2018, 09:11 AM
63 Nova SS's Avatar
Asking that clutch to hold 500 is a lot.
Old 02-24-2018, 04:07 PM
cw383's Avatar
Yeah, I never really expected it to, but I didnt expect it to hold the old engine either, but it held up like a trooper. The stock piston ring lands however had enough after 4 years of 300-432 hp and 120k miles.
Old 02-25-2018, 09:40 PM
Scooby04's Avatar
Impressive, looks like I'll settle for a gmpp clutch kit.
Old 02-26-2018, 08:04 AM
royce777's Avatar
i dont recommend full boost in first gear, but yes this clutch is more than capable.
Old 02-26-2018, 07:14 PM
Scooby04's Avatar
The owner before me put a zzp pcm I was looking for someone with hptuners in the NYC area to reduce it, but I've had the car like this since I got it 8 months ago.
Dart_SI
06-19-2017 12:08 PM
serega12
03-05-2013 12:38 PM
ionit2004
06-14-2012 07:44 PM
SSSnoop
03-11-2011 05:00 PM
Pyros777
10-30-2009 10:56 AM
Quick Reply: Gmpp clutch kit
