Just bought my dream machine
What's up guys? I finally bought an LNF sedan last month, and I love everything about it.
I'm considering adding mods, but I plan on keeping it light. Any concerns with a High-flow catted downpipe, ZZP intake tube, K&N Drop In filter, and a Trifecta canned tune?
You have the mods right except the canned tune. Spend the extra money and get a custom tune from someone reputable. Also I would recommend replacing your front rear control arm bushings and also go with a decent roasted trans mount. Powell race parts makes a good mount and bushings.
07MetallicSC (04-27-2019)
Check out Powell parts I thinks it’s Powellraceshop.com for a rear sway bar, motor and tranny mounts and Contol arm bushings, contact Gloria they make some lowering springs that are top notch too. Almost forgot his air oil separator too
And it's not painted black!
Id lean more to a k&n sri, youll like the noise and it flows. Im running the high flow zzp dp and have no issues on the gms1 tune. If your gonna spend money for a tune then get a good hp tune from one of the amazing tuners we have on here. Suspension mods described above are also good ideas.
Thanks for the replies guys!!
Sorry if the format is **** here, this is my first time on a forum and I'm pretty sure this is how I can respond to everyone in one post
Ok, I'll see about where I can get a tune in my area. I'll also check out Powell for the bushings and the trans mount, I appreciate the advice bro
Thanks! I went to a car meet at my local racetrack and there was a burnout competition. I didn't participate, but the smoke filled the entire event lmao
Shidd I'll see about the sway bar too, but I can't get lowering springs bc my area's got a shitty roads, full of potholes and speed bumps The Air Oil Separator sounds like a good idea, good to prevent problems before they start ig lol
Thanks!! (nice tail lights btw those look sick)
Nope! I love the silver, but if I ever have to get it repainted, I'm going with Imperial Blue
Dumb question, but what's an SRI? And how do ya like the GMS1?
damn, i got a lot to learn
Its this intake here https://www.knfilters.com/cold-air-i...balt/2.0l/2008
You can get it cheaper used or from other sites like zzperformance.com. I really enjoy it, brings out the turbo noises nicely and makes it so the bpv sounds like a bov. The forge bpv is just a bonus.
KMO43 (04-24-2019)
KMO43 (04-24-2019)
^This is true about the forge bpv, its not for performance gains in any way, only for fun noises. I wouldn't have got one if I hadn't come across the nearly new one I got super cheap. I was able to get it at like 60 or 70 bucks shipped.
The Powell trans mount is all you will need. Factory engine mounts are just fine. The gms1 tune is ok, but since your car isn't under warranty now there isn't any use in going with it. I would NOT go to just any tuner. Make sure they have experience tuning di turbo cobalts because if you don't it's easy to grenade the engine. I had gms1 to start with and it's a nice little safe bump in power but if you have mods like a downpipe it won't take advantage of the better flow as it's capped at 285 engine hp in the computer. Then I went with trifecta and it was slightly better because they could take the factory limits off to be able to gain more power with mods. The car never ran great on the trifecta tune. Then I purchased hp tuners and got a remote tune from a guy on here back then that really made the car awesome.
lmao looks like I’ll be skipping the BPV then if it doesnt do anything. Thanks for the input))
HP Tuners is the means of performing a tune, not a "tune" itself. It is used by a "tuner" to create a custom tune for your car. This is contrasting a "canned" tune, where you either send your ECM somewhere or someone sends you and interface and reconfigures your ECU. Using a tuner to custom tune your car is more expensive, but the product is much better.
