forged vented bpv
Old 07-13-2019, 10:27 PM
Cobalt4209's Avatar
forged vented bpv
Im thinking of ordering a forged vented bpv from modern performance, does anyone know how i can tune for this with hp tuners ?
Old 07-14-2019, 01:23 AM
Cobalt4209's Avatar
Nvm Just remembered My lower charge pipe came with a maf relocation with wire extension lol.
Old 07-14-2019, 12:26 PM
cobaltss#01's Avatar
So am I to understand that if you put this on and just use the maf relocation you don't need to change your current tune?
Old 07-14-2019, 12:44 PM
Cobalt4209's Avatar
All you would.have to do is retune the maf
Old 07-14-2019, 04:34 PM
Cool thanks.
Old 07-14-2019, 06:14 PM
Cobalt4209's Avatar
k just to update i relocated the maf and at first it ran like a pig so i changed the maf base table too all 1s then i multiplied my hole freq table by 1.15 . This fixed my idle and it runs pretty good +/- 5 on the trims. all i gotta do now is log and dial the trims in and its done , Im ready for my forged vented bpv when it arrives
Old 07-17-2019, 08:45 PM
Cobalt4209's Avatar
Just to update I had to switch my maf back to its stock location. I noticed it was running real rich at wot and the afr was all over the place under boost . I do not need to destroy my ring lands and runing that rich sucks lol. The commanded vs actual afr was way off . I would rather have it run rich between shifts for a second with my vented bpv rather then always running rich . Im gonna figure out how to tune with my maf in its stock location . I wish we had access to pe tables.....
cobaltss#01 (07-18-2019)
Old 07-17-2019, 09:50 PM
tomj77's Avatar
doing ur fuel trims one time isn't tuning for a basically bov. get it done properly
Old 07-18-2019, 12:54 PM
Cobalt4209's Avatar
I was tuning the trims all day coundnt get my wot afr right it was off by 13 % . Running .74 lambda at wot when it was commanding .85. Now i think i made a mistake by adding 15% to my maf freq at the beginning when i was suppose to subtract 15% So Im gonna give it another shot.
Old 07-18-2019, 01:38 PM
Cobalt4209's Avatar
noticed in my logs the car is going into open loop during wot this is where the afr goes out of wack . During a wot pull it goes from closed loop to open loop then back to closed loop during open loop my afr is rich ...
Old 07-19-2019, 01:38 AM
Cobalt4209's Avatar
k started with a stock tune and the maf was pretty close dialed it in over several logs and my afr is bang on now . Im not sure but the tune i built off of previously was a zzp tune i had . I think they have access to other tables that were messing with my blow through setup cause once i started with a stock tune things worked properly. Also i switched out my maf with a spare i had so that might of been the difference as well.
Old 07-19-2019, 07:17 PM
tomj77's Avatar
did u accidently do something with fuel on the previous tune before u started over?
Old 07-21-2019, 09:00 PM
Cobalt4209's Avatar
Nope . It might of been the maf sensor itself causing the problems .
Old 07-24-2019, 05:58 PM
Cobalt4209's Avatar
Well got the forged vented bpv installed it sounds awesome . The only problem im having is it will blow off at the slighted throttle and it also stays open while cruising at the right rpm . Is this because the spring in it is to weak or is it the wastegate demanding boost to early ?
splash
11-25-2015 02:41 PM
blueLNFftw
Tuning
17
11-20-2014 05:14 PM
Waka Flocka Fluff
06-07-2014 04:23 PM
Konvikt21
03-21-2013 08:45 PM
steven6870
04-08-2010 10:36 PM
Quick Reply: forged vented bpv
