Appearance: How to: Change the color of the LED's on the Projectors
Old Jun 15, 2007 | 11:15 AM
refuge4's Avatar
I recently decided to change the color of the LED's in my projectors. I felt that the white LED's that originally come installed with the vehicle to amber to match the turn signal and the orange color of the vehicle. I purchased 6 194 amber Oval LED's that are 12V from Auto Lumination . I purchased their oval lens LED's. These are the same size and lens of the originals, but are just 12V instead of 4V. The problem about installing these into the original wiring is that the LED's are wired in series.
Here is a diagram that shows how the lights are wired. What this does it take the 12V that the car supplies are shares the voltage across all 3 LED's. This will only allow 4V per LED. This is not enough to light the new LED's. Here is how you will need to do complete this mod.
Note: You can remove the headlight from the vehicle. This would make things easier but I decided not to. Also, these instructions assume that you have already gone though mkulrey13’s how to wire up halos for projectors.
1. Remove the light sockets that are in the projector. They pull right out.
2. Cut the 2 wires that are supply the power to the LED's.
3. Cut the wires that are connecting the 3 sockets together.
4. You will need to install the sockets in parallel. This will supply 12V per socket, This will allow the LED's to have enough voltage to light. Here is a diagram to show how you will need to wire them. You might need to add some extra wire so that you can have enough to reinstall the sockets.
5. Install the new LED's into the sockets.
6. Turn on the parking light to see if the LED's light. If they don't, turn off the parking lights and remove the LED. Turn it a half of a turn and reinstall it into the socket. If this does not fix it, recheck your connections to make sure that everything is properly connected
7. Reinstall the sockets into the projectors. They are kinda difficult to install into the projectors. The rubber sockets will catch on the edges. just keep pushing on them and they will finally slide into place.
That is all that is needed to change the color of the LED's. Here are the picture of them after they were installed. They are from my camera phone, but they will do good enough to show how this changed them. Sorry I did not take picture of this while I was installing them.
Halo’s and Fog Lights
Front Corner
LED’s
Here is a picture of the new LED’s with Vision Bulbs 4300K HID’s and Luminics JDM Yellow Fog Lights.
Close Up.
Nighttime
NOTE: If you are purchasing just LED's and not the LED's that are in a 194 bulb socket, DO NOT FOLLOW THIS HOW TO. Doing this will cause the LED's to blow because of the extra voltage.
Last edited by TommyP; Oct 6, 2012 at 09:14 AM. Reason: cleaning up typo's and fixing links
Old Jun 15, 2007 | 12:05 PM
brandisnez's Avatar
awesome was wondering how to go about this!!!
Old Jun 15, 2007 | 12:08 PM
REIGN SS's Avatar
Original Hayden Fanatic
Nice, looks great!!!
good howto, i like the diagrams
Old Jun 15, 2007 | 02:41 PM
Sicklyscott's Avatar
Do you know if the LED's for the halo's are lit with the same LED? If so, can you post a link of where you got those LED's? I know lots of people are having problems with them blowing out.
Thanks!
Old Jun 15, 2007 | 02:46 PM
brandisnez's Avatar
thats also another thing im trying to find out
Old Jun 15, 2007 | 02:54 PM
refuge4's Avatar
Thanks!
I don't know about the Halo's. The person that you would probably want to ask is mkulrey 13. He is the LED specialist. All that I made this how to for was for the 3 LED's in the top.
Old Jun 16, 2007 | 12:56 AM
refuge4's Avatar
EDIT: links have been fixed
Old Jun 16, 2007 | 01:02 AM
Scythe_Snake's Avatar
Nice how to!
Old Jun 23, 2007 | 12:34 AM
Psykostevo's Avatar
I had one halo LED blow out last week, need to get it fixed
Old Jun 23, 2007 | 09:10 AM
reed's Avatar
Ummm...no pictures or links?
Old Jun 24, 2007 | 10:50 PM
refuge4's Avatar
Try and refresh the page. It works for me.
Old Jul 24, 2007 | 01:20 AM
njlopez3's Avatar
Thumbs up
awesome how-to! thanks..
Old Jul 26, 2007 | 11:32 AM
farfrmnormal's Avatar
Umm, not to drag out an old thread but I replaced my LEDs with the same ones and didn't have to re-wire anything - they lit up fine just by plugging them into the slots. Mine are the round inverted ones & are 12v 194 bulbs.
Old Jul 26, 2007 | 11:36 AM
JPizzle's Avatar
Where did you get yours at farfromnornal?
Old Jul 26, 2007 | 11:38 AM
I bought mine off of Ebay
Here
I got 20 of them for about 15.00 shipped to me.
Also, I have purchased from this company in the past. When I had my Cavalier almost every bulb in it was 194 and the bulbs lasted about 3 yrs in the car (from the time I put them in, until the time I got rid of her). I still had some left over from the first time - this is what I am using in my projectors right now.
Old Jul 26, 2007 | 02:14 PM
refuge4's Avatar
That is cool. Yours might have a lower minimum voltage than mine. Mine would not light up no matter how I turned them in the original wiring.
I used an oval lens 194 bulb. From what I could see, it was the same as the original bulbs in them.
Old Sep 29, 2007 | 04:22 PM
Pyros777's Avatar
*back from the dead*
Just want to say thanks to refuge and farfrmnormal for their input.
Old Oct 14, 2007 | 04:02 PM
wdsoccer's Avatar
i just tried this and the middle LED and teh one closets to the grill flashd once and burnd out
is the resistor suposed to go after all the leds are wired together? like solder all the wires together for the power then have the resistor?
Old Oct 15, 2007 | 10:32 AM
refuge4's Avatar
Did you just replace the LED on top of the 194 bulb socket or did you replace the whole thing?
Old Oct 15, 2007 | 11:54 AM
wdsoccer's Avatar
i was replacing the 3 upper leds in the headlight
i was following the how to. i was using 3mm leds
Old Oct 15, 2007 | 01:35 PM
refuge4's Avatar
Did you buy the LED's that had already been wired into the socket or were these lose LEDs?
Old Oct 15, 2007 | 05:21 PM
wdsoccer's Avatar
they were ones from murkley13 for the led cupholder kit. i didnt do the rear cupholder so i was gonna put them in the lights but they burnd out.
Old Oct 15, 2007 | 05:40 PM
refuge4's Avatar
If that was the route that you went, you probably should have left the LED's wired as they were. The LED's were originally wired that way with the resistor on them because they were sharing the 12 V. This gave each LED 4V of power. The LED's that I bought were for a 12 V aplication. That is why I had to re wire mine. Sorry for the trouble that this caused. You can PM me with any other issues that you have with it and I will try to help you.
Old Nov 8, 2007 | 07:05 PM
BlackLsCoupe's Avatar
thanks for the tips i was planing on makeing my halos green and the 3 leds amber so it matches the turn signal
Old Nov 14, 2007 | 11:06 AM
MexG4's Avatar
good howto, i like the easy diagrams!! thanks
