235/40 18" Tires on the SS/SC
Old 02-03-2008, 10:41 PM
rallyracer's Avatar
It says this size tire is for a 8in wheel and ours is only 7...So for those of you with the 235/40 18" Tires have you had any problems?
215/45R18 vs 235/40R18 using http://www.1010tires.com/TireSizeCal...?action=submit
Tire - 235/40R18
Rim Diameter: 18 in 457.2 mm
Rim Width Range: 8 - 9.5 in
Speedometer Difference: 0.825% too fast
Diameter Difference: 0.82%
Old 02-04-2008, 11:08 AM
rallyracer's Avatar
Please help, I dont wana buy a tire that gonna fall off my wheel
Old 02-04-2008, 11:13 AM
mscobaltss's Avatar
well i have 245x35x18 and my wheels havent came off yet lol ur fine with that size
Old 02-04-2008, 11:14 AM
quadracer0387's Avatar
dont do it... it will ride shitty, and will buldge in the middle... go with 225/45/18
plus the hight difference will mess with you anti lock brakes... not good
Old 02-04-2008, 11:19 AM
BlackSS/SC's Avatar
Go with the 235/40R18s! They work fine on stock wheel, mine are not wearing bad in the center and do not bludge. I've had them on for 20 000kms so far and it's all good.
Old 02-04-2008, 11:22 AM
rallyracer's Avatar
Why do you say it will ride shitty?
Why is the 225/45 better?
Old 02-04-2008, 11:29 AM
well if there isnt any bulge you would be fine, but if it crowns some, not all the tread will have full contact on the street
225s are closer to the stock hight
Last edited by quadracer0387; 02-04-2008 at 11:29 AM. Reason: Automerged Doublepost
Old 02-04-2008, 11:31 AM
rallyracer's Avatar
If that is ture then why does http://www.1010tires.com/TireSizeCalculator.asp say different?
235/40R18 = Diameter Difference: 0.82%
225/45R18 = Diameter Difference: 1.39%
Old 02-04-2008, 11:33 AM
BlackSS/SC's Avatar
235/40R18 is fine, won't F the ride up or anything. I'm in the tire industry and this is an acceptable size.
Old 02-04-2008, 11:35 AM
Edubs's Avatar
Doesn't it really depend on the specific tire? Don't some tires sit differently than others?
Old 02-04-2008, 11:41 AM
tires vary in size, some brands are different than others
as long as you dont go +/- 3% of original stock size you should be fine
Last edited by quadracer0387; 02-04-2008 at 11:41 AM. Reason: Automerged Doublepost
Old 02-04-2008, 11:42 AM
BlackSS/SC's Avatar
^^^What he said^^^ They should all be pretty damn close as long as they are the same size.
Old 02-04-2008, 11:44 AM
Hopeless Regret's Avatar
I have 235 40 18 on mine and have no issues you have nothing to worry about
Old 02-04-2008, 12:23 PM
rallyracer's Avatar
Thanks for all the comment.
Old 02-05-2008, 04:54 AM
tim0shel's Avatar
Thanks everyone because im about to use the same size for mine. I been looking at the falken 912's
Old 02-05-2008, 04:59 AM
syP
syP's Avatar
i roll 235/40/18... Not on a stock rim tho...
rides great!
JRelly's Avatar
225s FTW
Old 02-05-2008, 05:01 AM
syP
syP's Avatar
Originally Posted by JRelly
BTW stock tires fit 18x8s
not sure why you would wanna do that though.. it will bow inwards and look super cheap.. plus not protect the rim
Old 02-05-2008, 05:07 AM
JRelly's Avatar
edited my post becuase I didnt read what he was wanting to do but actually a 215 fits nicely look at 06_SS_S/C's car
https://www.cobaltss.net/forums/showthread.php?t=92318
Old 02-05-2008, 05:58 AM
Jackalope's Avatar
I run 245/40 18's all around and hve ZERO problems. Their over all diameter is very close to the stockers and no it doesn't hurt the ABS at all. For it to screw with the ABS you'd need to run 2 very different tires height wise from front to rear.
That calculater is a little off depending on the manufacturer of the tires. When you compair the bigger size tire go off what the manufacturer of the tire says it is. When I compaired my 245's they came out to be not quite .5 mph off but this link says its off by way more.
Old 02-07-2008, 04:33 AM
tim0shel's Avatar
Well i ordered my tires dont know when they will be here but when they do and i get them on i will give an update.
what i got... Link below
http://highperformancetire.com/produ...age=1&featured
Old 02-07-2008, 08:47 AM
Kibosh3's Avatar
theres no rubbing issues with the 245s? or even the 235s? ....and im also looking at the falken 912s
Old 02-07-2008, 09:08 AM
Jackalope's Avatar
245's hit if your dropped on sportlines, load your trunk all the way up and pack 4 people in the car. Then the rears hit a little when you hit bumps hard.
Old 02-07-2008, 01:18 PM
saunders1986's Avatar
i'm running 225/45/18's on my 18x8 wheels. i think my next tire size will be 245/35/18
Old 02-07-2008, 01:19 PM
EceSSiveMod's Avatar
no 225/40/18
Quick Reply: 235/40 18" Tires on the SS/SC
