2.2 to 2.4 engine swap
I found a 2008 Cobalt with a man trans the car was rolled If I buy this car will the 2.4 bolt up to my 06 2.2 Auto trans or should I change the trans also my plan is to put a stage 2 turbo on the 2.4
Kinda interested to know.
PS. May want to start using punctuation. Really hard to read.... |
punctuation, proper section of the forum, the search button, the list goes on.
Yes it bolts in place. No it wont work. |
You'd probably want to swap everything. Computer, engine, harness. And probably some other things. Probably more work then it's worth.
trans is the same.
cant do it with out a stand alone ecu because the crank triggers are different
Maybe before finding an engine find the proper section of the forum
