2.2 to 2.4 engine swap
I found a 2008 Cobalt with a man trans the car was rolled If I buy this car will the 2.4 bolt up to my 06 2.2 Auto trans or should I change the trans also my plan is to put a stage 2 turbo on the 2.4
You'd probably want to swap everything. Computer, engine, harness. And probably some other things. Probably more work then it's worth.
patooyee
Oct 1, 2015 01:07 PM
