Recalls Chevy Cobalt recall information center
brembo pins are stuck help me!!!
Old Mar 17, 2017 | 09:07 PM
bahoodle's Avatar
my pins will not come out :'( do u guys think i need new calipers? er should i try cutting grinding then drilling the pins out :/
Old Mar 17, 2017 | 10:00 PM
Well by the end you will need new pins, have you tried using a punch?
Old Mar 19, 2017 | 12:01 PM
cluelessk's Avatar
Mine were pretty bad. Ended up starting to damage a caliper so I pulled it off and brought it to a machine shop. They charged me a half hour.
Old Mar 20, 2017 | 09:48 PM
bahoodle's Avatar
so im thinkin about getting a little torch n trying again but b4 that i read that if i poor boiling water on them that i may b able to get them out? idk im thinking about trying that b4 using a torch on em :/
Old Mar 21, 2017 | 12:11 AM
double clutch's Avatar
I had to cut mine off with a dremel.
Old Mar 21, 2017 | 10:54 AM
rreineck's Avatar
Had that issue before. Used a propane torch to heat them up a little then used a tap to remove. Needed new pins after this and don't forget to grease them throughout the year.
Old Mar 21, 2017 | 05:19 PM
Hemphog's Avatar
I think you will get them out one way or another...if not PM if interested in my spare TC calipers.
Old Mar 21, 2017 | 05:22 PM
bahoodle's Avatar
believe me i know now.. ive only had the car since november last year ive done the back brakes twice since they get stuck pretty easily n i tried doin the fronts but had no luck i just gotta torch n ordered pins from zzp so hopefully i have some luck this weekend when they get here :/ now what do u mean cut em out with a dremel? like using a mini cutoff wheel wit a dremel? what do u do after that did u dril it out or punch it out?
Old Mar 21, 2017 | 05:25 PM
bahoodle's Avatar
n ya i for sure will how much would u want for em cuz new ones r like 390 bux :/ and thats about what i make in a week so im tryin to avoid that lol
Old Mar 21, 2017 | 06:23 PM
Hemphog's Avatar
Originally Posted by bahoodle
n ya i for sure
Really reasonable for a fellow CSS, check your PM.
Old Mar 25, 2017 | 02:27 PM
bahoodle's Avatar
well i took the caliper off cut the pins w/ a sawzall n the front ones came out easily w just a vicegrip holding them n a hammer but the backs i had to heat up pretty good n beat the **** outta them til they came out :P i actually bent the one pin but then i was able to get vicegrip on it to get it turnin so i sprayed it w pb blaster while turning it cut it n then it came out. the inner pad was seized to the caliper and they were brembo pads so idk if theyve ever been changed lol
Old Mar 25, 2017 | 02:44 PM
Well already you got everything off now lol
Old Mar 25, 2017 | 04:38 PM
I cut the pins on both sides and removed the pads to release the tension on the pins. Then I pounded them out with a punch. You got it figured out tho.
Old Jun 15, 2018 | 09:03 AM
Kostyhhrss's Avatar
So, I won. I spent 3 hours on 2 calipers, pulled without removing the caliper and any damage.
but of course there was a magic device
Last edited by Kostyhhrss; Jun 15, 2018 at 09:46 AM. Reason: https://m.youtube.com/watch?v=XYj8Nr0mHWc&feature=youtu.be
Old Jun 15, 2018 | 12:57 PM
cluelessk's Avatar
Nice. Mine mushroomed and needed to be drilled out.
I put anti seize on my new ones and take them out annually.
Cobalt08tc
Jan 23, 2014 07:51 PM
Cobalt08tc
Jan 19, 2014 03:42 PM
Cobalt08tc
Jan 18, 2014 10:27 PM
Cobalt08tc
Jan 18, 2014 05:21 PM
BNS06Mike
Mar 30, 2012 12:10 PM
