Carolina Cobalts
#6829
well if I replace the engine itll be a whole new car lol. even replaced the coupler on the m62. got brand new shocks/struts waiting to go on when I get new springs. brand new moog CABs and end links installed. new brake pads. lol new clutch etc.
#6833
took the chrysler emblem off the trunk
Now trying to see what is a good way to remove the what I call Ghost residue. I used goo gone, even tried clay bar and elbow grease but nothing worked. Not noticeable in the pic but if you look in the lower left of the trunk I took the dealer decal off and it left similar residue behind you can see.
soak in in goo gone.
let it sit for 5-10 minutes.
heat it a little more.
roll it off with your fingers.
#6835
heat is key
Youll cry more when you see the NADA value on your miles.
Even more when people ask you to pull the trans for the gears. Lol.
#6836
ahhh, finally all done. Got rid of the 200 and S badge too, luckily those were not half as bad as the decal and chrysler one. I just wish I could get rid of the one in the front grill but if I did it'd look bad. I thought about blacking it out but that can look cheap.
#6848
I know they are in good shape. But I burn $80 in gas just going and coming, so that will probably be the deal breaker for me, especially since I have to put gas in it right when I get back home. So technically $120 in gas.
