South East MS, AL, TN, GA, SC, NC, and FL
How many bets
Old Feb 10, 2007 | 10:35 PM
NinjaHampster's Avatar
you should do a how to with pics
Old Feb 11, 2007 | 01:54 PM
seoulgirl7's Avatar
i will take pics...but there is already a how to on it ill try to see if i can just add some more
now im pissed....the dealership took my damn lug wrench.....anyone know where i can get another?
Last edited by seoulgirl7; Feb 11, 2007 at 01:54 PM. Reason: Automerged Doublepost
Old Feb 11, 2007 | 02:27 PM
rickyw's Avatar
nope. the pics that helped me out was the how to change your air filter remove the front drivers tire, remove screws and go forth
Old Feb 11, 2007 | 06:17 PM
seoulgirl7's Avatar
WOOHOO...it is done...loading pics now
The hardest thing was gettin those damn clips off and back on! It was really easy, if u got a brain....but i think i may hav fractured my elbow tryin to pull off the hose from the stock pipe ....but other than that it was allll good!
Last edited by seoulgirl7; Feb 11, 2007 at 06:17 PM. Reason: Automerged Doublepost
Old Feb 12, 2007 | 01:49 AM
how much was your hydrosheild?
Old Feb 12, 2007 | 02:05 PM
seoulgirl7's Avatar
got it at autoanything.com for i think 22 dollars....also....i have absolutely no noise ? nice and quiet, is this normal? I feel a big difference in the smoothness as i accelerate tho
Old Feb 12, 2007 | 02:09 PM
LaserblueSS's Avatar
no noise?? as in no whine?? cause thats not good. you should be able to hear that thing scream!
Old Feb 12, 2007 | 02:14 PM
seoulgirl7's Avatar
nope, no screamin...would it be cause i have the hydroshield on it? or clamps not tight enough?
Old Feb 12, 2007 | 02:18 PM
hm, i dont know if that hydro shield would make that much of a difference. if you arent getting any type of loud whine, then i would check the clamps. if it is that hydroshield, then its not letting you get near enough airflow.
Old Feb 13, 2007 | 01:35 AM
Cobalt_Supercharged's Avatar
Hydro shield makes no difference. I have the same set up only in black. I'm not sure why you wouldn't get whine, unless you aren't getting over 5 psi of boost. Anything under 5psi it's barely noticable if at all.
If you are not getting full boost you may want to check your vacuum lines and the bypass actuator. (see below)
Old Feb 13, 2007 | 06:49 AM
  #36
seoulgirl7's Avatar
got it thx!
Oxity-X
May 11, 2006 08:53 PM
BobWreck
May 10, 2006 02:13 PM
