South Pacific CA, NV, and HI
supercharger or turbocharger? that is the question
Old Sep 8, 2009 | 12:01 AM
G.I.JO.G5's Avatar
gimme your opinion i have the opertunity to get a supercharger so tell me what you think
Old Sep 8, 2009 | 12:07 AM
nealscobaltlt's Avatar
turbo of course.
Old Sep 8, 2009 | 12:28 AM
G.I.JO.G5's Avatar
why turbo
Old Sep 8, 2009 | 12:38 AM
stoon_cobalt_colby's Avatar
go supcharged sounds cooler
Old Sep 8, 2009 | 12:42 AM
krishansheanh's Avatar
turbo, cheaper to make faster, and everyone jizzes to the sound of a BOV
Old Sep 8, 2009 | 12:57 AM
G.I.JO.G5's Avatar
I can get a supercharger for1500
but what I need to know is what will crest more power
Old Sep 8, 2009 | 01:09 AM
turbo should
Old Sep 8, 2009 | 02:27 AM
HunterKiller89's Avatar
if you're not going to build the motor, go supercharger. its cheaper, and has a flatter torque curve.
if you're gonna build the motor, and have the cash, a turbo will get you the most power.
Or you could do both...
Old Sep 8, 2009 | 02:29 AM
silver187666's Avatar
see most knowlegeable
Old Sep 8, 2009 | 09:54 AM
G.I.JO.G5's Avatar
ok ok i think im going to go with turbo but i wounder how hard it would be to do both. I wounder the mods i wouls have to do for that?
Old Sep 8, 2009 | 01:46 PM
you going to redo the internals first? i think its around 2.5 k to redo them, and if you are going to skip that step get ready to paya lot more when your engine blows
Old Sep 8, 2009 | 01:52 PM
reign1's Avatar
2500 bucks for internals?
all he needs is pistons and rods. hes not pushing 300+ HP
turbo system with rods and pistonsshould b about 250-280 or so HP.
might need a new clutch tho if ur manual
Old Sep 8, 2009 | 01:53 PM
06_SIC_SS's Avatar
Originally Posted by nealscobaltlt
turbo of course.
dont be that guy..
ei3dag3's Avatar
very true, i may sound biased...but its the truth.
the reason i went with a supercharger is because you can throw a 2.8" pulley on it and get 16 lbs of boost and still be safe you can still do that with a turbo, but in past history here on css, 2.2 guys with turbos have done engine builds...some even after their engines blew lol.
i've got some major plans for my car and that is why i'm getting rid of my kit.
i want power yields in the 380-400 so i will be doing a lot and eventually going to use a turbo.
but if you're not gonna build the engine right now you might as well sc.
you get instant boost no matter what rpm, and a turbo will take time to spool.
if you want lots of power go to turbo, if you're happy with 250-280 hp go with a supercharger.
also keep in mind a turbo requires oil lines to be tapped into engine, or oil pan.
then possibly a coolant line taped into the radiator lines that cycle that coolant.
you also have to route all the piping with proper t clamps or you will have plenty of boost leaks, and engine shutting off.
you will also have to get a new downpipe made for the o2 housing of the turbo.
a supercharger will just bolt on, and after a tune with trifecta go.
Old Sep 8, 2009 | 01:54 PM
06_SIC_SS's Avatar
not true..BOVs can be annoying as hell..
Old Sep 8, 2009 | 01:57 PM
ei3dag3's Avatar
http://www.turbotechracing.com/produ...dcategory=5616
- rods 339
http://www.turbotechracing.com/produ...dcategory=5616 -pistons 500
http://www.turbotechracing.com/produ...dcategory=5615
-clutch 434
plus install.
if you're going to spend all the money gettin someone to tear apart your engine and do it for you....why just to rods, and pistons?
why not do valves, sleeves, gaskets, etc.
do it all.
but anyways, theres a lot that can be done just need mullah
it may not be 2500 for engine parts.
but you're looking at 1200 in parts if you're really looking to get between 250-300 and be on the safe side with an engine build.
my clutch and flywheel install costed me 450.
i don't know what an engine build would cost but i'm sure it'd be over 500-600.
easily close to 2000+
Old Sep 8, 2009 | 02:06 PM
buellfooll's Avatar
How about a turbo 1250 HP, destroked 2.2? It's being done. And a turbo is much easier to install. You really don't even need a manifold. There are people running around with turbos mounted in the trunk. In fact, depending on your cubic bucks you could go with a 2.0 LNF and get a forged crank and rods and forged pistons are available for the DI from Wiseco now. The block and heads are good for 500HP. After that it starts getting cost prohibitive unless your going pro racing.
JMHO considering what I have read.
Old Sep 8, 2009 | 02:08 PM
another one of these threads....
Old Sep 8, 2009 | 02:14 PM
reign1's Avatar
come race me from a dig or roll. ill show u how much turbo lag is on the K04.
Old Sep 8, 2009 | 02:20 PM
buellfooll's Avatar
Which thread is that?
http://aerocharger.com/kits_pontiac_g8.php
http://www.thirdgen.org/techboard/po...unt-turbo.html
I pass that along to the pro Cobalt racers.
Old Sep 8, 2009 | 02:25 PM
reign1's Avatar
*******. hehehehe
Old Sep 8, 2009 | 02:28 PM
reign dont you have launch controll? or a wot box?
Old Sep 8, 2009 | 02:41 PM
buellfooll's Avatar
*******. hehehehe
Why am I an ass hole? Just because you're not intelligent to understand it?
Copy and paste then scroll down to the G8. If I'm an ass hole you MUST be a dick head you ******* brain dead **** ant.
http://aerocharger.com/videos.php
Old Sep 8, 2009 | 02:42 PM
Supercharged Guy's Avatar
Turbo deff makes more power...better bang for your buck
Old Sep 8, 2009 | 02:48 PM
ei3dag3's Avatar
again, when looking at price for price and engine for engine
i think the op wants to go for cheapest.
building an engine, isn't cheap.
i like both sc and turbo.
i currently have a supercharger, but am selling it cause i have some major plans and i will be using a hanh 20g or gt30r.
and your stock k04 was designed to have minimal lag, thats how chevy designed it.
aftermarket kits are not usually the same.
regardless you still have lag, and sc is instant.
no arguing around that.
theres not point in arguing which is better they are both great.
just giving op insights to both sides, and let him make up his mind.
