For Sale 10" subwoofer & amp
10" subwoofer & amp
I have a 10" JL Audio subwoofer in a custom built box by Tweeter for sale. I also have an Alpine MRD-M301 mono amplifier that pairs up perfectly w/ the subwoofer. The amp has all terminal screws and fuses but i was never given the cover plates that go over the terminal strip. I used this setup for 3 years in the same vehicle and is in awesome condition. Im also including: 18ft. 8gauge power cable with 40amp inline fuse/12ft. shielded platinum RCA cable/3ft. 8gauge cable/and 3.5ft. 12gauge speaker cable. Ground cable has a minor cut in the insulation but the wire inside has no damage. <-this is fine b/c its the ground cable. All wire is Scosche oxygen free/high current cable.
Here are the amp specs:
-175 watts RMS x 1 at 4 ohms (CEA-2006 Compliant)
-350 watts RMS x 1 at 2 ohms
-2-ohm stable
-MOSFET power supplies
-Bass Engine® features:
low-pass digital crossover, 30-200 Hz, 12 or 24 dB/octave
variable subsonic filter (15-50 Hz in 5 Hz steps)
parametric EQ variable from 30-160 Hz
Bass Compensator enhances low-end definition
-top-mounted controls with digital readout and cover
-speaker- and preamp-level inputs
-gold-plated terminals
-9-9/16"W x 2-9/16"H x 10-5/8"D
Subwoofer box specs:
Felt is jet black, just doesnt look as good w/ the yellow lighting
15.25" tall - 22.25" long - 5.25" top width - 8.5" bottom width
missing red part of the terminal nut, but the metal part is still there and works fine
Here are pics of everything the buyer gets as is:
Pics of sub+box:
Pics of amp:
Cables:
Im asking $250+shipping. Manheim, PA
-2-ohm stable
Pics of sub+box:
Pics of amp:
Cables:
im not sure. i so know that there is 3 different ranges you can pick from when i bought this and i picked the middle range. range one was for "jazz" type music. 2 was for "rock" and 3 was for "rap" type music. mine was the 2nd range so its a nice medium. this sub kicks ass! of course its a JL so you already knew that...
