FS: Xtant X604 Amp BRAND NEW
Old Apr 28, 2009 | 10:33 AM
Blue04RedLine's Avatar
Hey guys, I'm selling a NEW Xtant X604 amp. The price is $450 OBO + Shipping (if you're paying with paypal, just ask 1.5% over that to cover part of their fees). Let me know if you're interested. Local pick up would be awesome to avoid shipping, but the box is packed and ready to ship.
Here are some specs on this beautiful and powerful amp (which still has the white vinyl covering over the stainless steel case):
- 600W RMS 4-channel Amplifier
- Stainless Steel Cover
- Fully Regulated PWM MOSFET Power Supply
- 4 Modular Expansion Ports: Used for docking Xtant's signal processors
- Forced Convection Cooling
- Balanced / Floating Input: Helps to eliminate noise
- Protection Circuitry: Thermal, Overcurrent, and Low Voltage Protection
- Status LEDs: Red On, Yellow Overcurrent Protection, Orange Thermal Protection
- Input Sensitvity: 100mV - 8.5V RMS Unbalanced / 100mV - 17V Balanced
- Input to Line Output Gain: -20 - 20 dB, Selecable 10 dB Steps
- On-Board Crossvoer: 12 or 24 dB/Oct Butterworth
- Line Outputs: Yes, High Pass, or Bypass Mode
- Operational Voltage: 11 - 15V
- Crossover Variable From 10 Hz - 5khz in 12 Steps
- Dimensions: 20-11/16" L x 10-5/16" W x 2-3-16" H
- Number of Channels: 4
- Watts per Channel 4 Ohm ---- 4 x 75
- Watts per channel 2 Ohm ---- 4 x 150
- Bridged Mono at 4 Ohm ---- 2 x 300
- Module Ports 4-Accessory
- Peak Power Output ---- 1200 watts approx.
- Minimum Impedance Unbridged ---- 2 ohms
- Minimum Impedance Bridged ---- 1 ohm
- THD at Rated RMS Power >0.2%
- Speaker Level Inputs: No
- Preamp Outputs ---- 1 pair
- Built-in Crossover: N/A
- Signal-to-Noise Ratio >100 dB
- Bass Boost: Optional Accessory Required
- Fan Cooled: Yes
- Fuse Rating: 120A External Fuse Required
Old Apr 29, 2009 | 01:24 PM
Bump TTT...
Old Apr 30, 2009 | 03:27 PM
TTT.......
Old May 3, 2009 | 09:54 PM
TTT. Anyone with any offers?
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
Stuff
Oct 1, 2015 05:47 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
c_m_shooter
Sep 27, 2015 04:40 PM
