★★★ ARK Performance NOW @ THMotorsports!! FREE SHIP EPIC PRICING !!! ★★★
Old 06-12-2013, 06:05 PM
thmotorsports's Avatar
THMotorsports just partnered up with ARK Performance!!!
Since this happened we have EPIC pricing!!!!!
PM me for details, Pricing, Inquires!!!!
As you know we have the best pricing hands down and passing on the savings to YOOUUUUUU
Chevrolet Cobalt | 2005-ON | 2.0L/2.2L
ARK DT-P Coilover System
Spring Rate 7 kg/mm - 6 kg/mm
ARK Performance DT-P monotube coilover systems are fully adjustable with 16 levels of dampening to fit your street or track needs. Our suspension systems are engineered and designed based on knowledge from our Team ARK Racing motorsports division and Formula Drift experience. The DT-P system offers pillow ball top mounts which are more performance oriented and allow for better adjustment of camber.
ARK Advantages and Features:
- All Bolt-on System
- 16 Level Dampening Adjustment
- Street Comfort, Performance Spec
- Pillow Ball Mounts
- Mono-tube Shock Design to React Quicker and Operate Quietly
- Height Adjustable
Items Included:
Coilover System
*Canadian/International shipping cost, prepaid duty, and tax not included in pricing.
Chevrolet Cobalt | 2005-ON | All Models
ARK GT-F Lowering Springs
Drop / Rate - Front - 1.38" - Rear - 1.57”
Spring Rate - Front: 2.1-3.5 kg/mm - Rear: 1.2-7.7 kg/mm
ARK Performance offers high quality lowering spring kits that provide a clean drop, comfortable ride, and greater performance. ARK GT-F Lowering Springs are designed to provide drivers with dramatic improvement in handling characteristics and cornering. Drivers will feel a significant increase in steering response, better cornering grip entering and exiting out of turns with reduced body roll, and a lowered center of gravity while maintaining smooth and comfortable ride quality for daily driving.
ARK Performance GT-F Lowering Springs are designed by our suspension engineers and tested by professional drivers to find the perfect ride height and spring rate to deliver the best ride quality and performance without neglecting the driver's safety on and off the track. Our springs are the perfect combination with your OEM shock absorbers. They provide an excellent stance with your stock or aftermarket wheels, while keeping your tires on the road for maximum grip. Each spring is made from the highest quality materials, with the leading coiling technology, and is powder coated to prevent corrosion. ARK GT-F and GT-S Lowering Springs provide the ultimate suspension balance to give you confidence on any road or course.
- Improves Handling and Cornering
- Reduces Body Roll
- Works With OEM Shock Travel
- Comfortable Ride Quality
- Medium Drop
- Front: Approx. 1.38” Lower
- Rear: Approx. 1.57” Lower
Items Included:
Front Springs, Rear Springs, Silencer Hose, Installation Guide
Chevrolet Cobalt SS/SC | 2005-07 | 2.0L
ARK N-II Exhaust System - Polished Tip
Pipe Diameter - 2.5" OD
Sound Decibel - 92 Decibel @ 3000RPM
Diameter - 4.5"
Finish - Polished
The ARK N-II cat-back exhaust system offers straight-through technology, offset tip design, and large piping diameter. All of this creates a deep, throaty exhaust note while maximizing power output. This is great for high horsepower vehicles, including forced induction applications. The ARK N-II is full SUS 304 stainless steel which provides improved looks, durability, and corrosion resistance while maintaining the best fitment, sound, and performance. The ARK N-II exhaust system is a unique design that looks unlike any other exhaust system we offer.
- Straight-through Muffler Core
- Polished Tip
- SUS304 Stainless Steel Construction
- Fully Polished Finish, 2.5 inch Piping
- CNC Machined Flanges
- Exposed Micro TIG Welded
Items Included:
Axle-back Muffler, Mid-pipe, Bolts, Gaskets, Hardware, Installation Guide
ARK DT-S Exhaust System - Polished Tip
Sound Decibel - 87 Decibel @ 3000RPM
Diameter - 4.5"
Finish - Polished
With the many varieties of exhausts that ARK has to offer, the DT-Series premium exhaust provides the perfect combination of sound, style, and performance. The ARK DT-S premium exhaust has been carefully engineered and manufactured to ensure 100% satisfaction. With T304 Stainless steel, quality mandrel bends, and flawless welds, the quality of the DT-S exhaust is unrivaled. The DT-S exhaust is designed with tone control and multi-layer sound compression materials to provide the perfect pitch you are seeking. This exhaust not only provides great tone, but also is dyno proven to maximize performance and engine response. The DT-S exhaust comes in many premium tip finishes such as polished, burnt, and tecno. With all the different exhausts in the market, the DT-S premium exhaust stands out beyond the rest. The flawless manufacturing, perfect pitch, and clean style makes our premium DT-S exhaust the perfect choice for any car enthusiast.
- Polished Tip
- Fully Polished Finish Piping
- Dyno Proven, up to 12 HP / 9 TQ gain
Items Included:
Axle-back Muffler, Mid-pipes, Bolts, Gaskets, Hardware, Installation Guide
Chevrolet Cobalt SS/SC | 2005-ON | 2.0L
ARK Short Throw Shifter
Warranty - 1 Year
Material - CNC Machined AL2024
Reduction
Height - 1.5"
Throw - 35%
The most advanced shifter on the market with no expense spared in engineering, materials, or function. The short throw shifter comes complete with ARK trademark Apollo knob, and allows for faster shifting with a 35% reduction in throw. Its lightweight design enables quicker shifts and is engineered to help prevent missed shifts to third gear.
All the driving excitements begin with engaging the first gear. Gear shifting is the important key when maximum control over your ride. The positive feeling of your hand ensures the precise engagement of gears. It's all about when it comes to true performance driving is getting the right gear.
Most factory stock shifters are not designed for racing environment rather suited for everyday driving. For performance driving you should have a precise engagement of shifter for maximizing control over your car while it reduces shift travel or shift throw for fast gear acceleration without losing forward momentum. So the racing isn't very exciting until you equip with a right performance shifter.
ARK performance shifter offers durability and precision with high grade material, T-303 stainless steel, AL2024 aircraft-grade aluminum, and precision steel bearings for last long. ARK shifters are manufactured using the latest CAM-controlled machining and milling equipment for precise products and designed replace minimum key parts to bring a simple straightforward installation.
- CAD Designed Precision Shifter Assembly
- CNC Machined AL024
- Billet Aluminum Shift Knob
- Engineered for more Accurate Shifts
- Shift Throw Reduced up to 35%
- CNC Machined Aluminum Pivot Housing.
- Accepts OEM Shift Knob
- Height Reduction of 1.5"
- Reverse Lock Functional
Items Included:
Short Shifter and ARK Shift Knob
Warranty - 1 Year
Reduction
Height - 0-2.5"
Throw - 38%-45%
The most advanced shifter on the market with no expense spared in engineering, materials, or function. The short throw shifter comes complete with ARK trademark Apollo knob, and allows for faster shifting with a 38%-45% reduction in throw. Its lightweight design enables quicker shifts and is engineered to help prevent missed shifts to third gear.
- Billet Aluminum Shift Knob with Engraved Insert
- Shift Throw Reduced up to 45%
- Adjustable Height from 0-2.5" Reduction
- Non Reverse Lock
Items Included:
FOR BEST PRICING PM ME!! OR CALL!!!!!!
Give me a call 1-800-959-0145 ext 102 Ask for Alan
Email - Acastro@thmotorsports.com
AIM - AlancTHM
Old 06-13-2013, 06:53 PM
Happy Thursday!!! All PM'S are out!!!! Pm me if you have any questions!! OR NEED AMAZING DEALSS!!
Old 06-14-2013, 06:42 PM
BUMP!!! Happy Friday all!!! Be sure to PM me if you have any questions and we will give you the best pricing hands down!!!!!
Special discounts for this weekend!
Old 06-16-2013, 07:27 PM
Happy Fathers day! Hope everyone had a great weekend!!! PM ME FOR SPECIAL FATHERS DAY DISCOUNTS AND DEALS FOR THE WEEK!!!
Old 06-17-2013, 07:22 PM
Happy Monday!! Bump Pm me for availability and pricing!
Best price guaranteed
Old 06-18-2013, 06:58 PM
All Pm's are out!! Pm me if you need quotes/availability/deals!!
Old 06-19-2013, 06:38 PM
BUMP!! Quotes are out!! PM me if you have any questions or concerns
BEST PRICING GUARANTEED!
Old 06-20-2013, 07:09 PM
PM'S are out with quotes! Pm me for the best pricing on the whole forum!!
Lets make a deal!!
Old 06-21-2013, 07:40 PM
Happy Friday!!! Bump everyone got their pm's answered!!!!
If you are looking for the BEST deals pm me!!!
Old 06-22-2013, 10:03 PM
Saturday bump!!! If the Blackhawks win?!? I will give you a awesome discount!!!
PM ME!@ Have a safe weekend
GO HAWKS!
Old 06-24-2013, 07:12 PM
Happy Monday!! All PM'S are out!!! If you have any questions let me know!!!
BEST PRICES
Old 06-25-2013, 06:36 PM
EVERYONE HAS A QUOTE!!! PM'S are out!!! Got any questions PM ME!! Best pricing around!!
Old 06-26-2013, 07:11 PM
Happy Humpday!!! BUMP! PM if you have any questions!! Lets make a deal! Best pricing around!
Old 06-27-2013, 07:18 PM
BUMP!! Pm me if you have any questions or want AMAZING pricing!! BEST PRICES AROUND !
Old 06-28-2013, 06:42 PM
Happy Friday!!! Crazy party here in Chicago for the Blackhawks soo
PM ME FOR CRAZY BLACKHAWKS WIN DEALS
Old 06-30-2013, 07:31 PM
Bump! Happy Sunday!! I hope everyone had a great weekend!! I know I did!!!
SPECIAL DISCOUNTS THIS WEEK!! Why do you ask???
WELL ITS MY BIRTHDAY ON THE 5TH!!!! Im excited sooo DISCOUNTS FOR EVERYONE!!!
Old 07-01-2013, 06:55 PM
BUMP!! Best pricing!! NO ONE can beat OUR PRICE
PM me for a quote
Old 07-02-2013, 07:00 PM
Quotes are out! Have a great day! Pm me if you have any questions!
Old 07-03-2013, 06:53 PM
Bump We will be closed tomorrow July 4th and will be back Friday July 5th! PM me for the special 4th of July sale!!
Old 07-08-2013, 07:20 PM
Bump! Hope everyone had a great 4th weekend I know I did!!!
PM me for quotes or if you have any questions about anything!!
Old 07-09-2013, 07:16 PM
Bump!!! Pm me for amazing discounts!! Everyone has a PM back from their previous pm's
Old 07-10-2013, 07:25 PM
Bump!! All pm's are out!! Best pricing guaranteed!!!
Old 07-11-2013, 06:42 PM
Happy Thursday!! Pm me for quotes!
Old 07-15-2013, 07:21 PM
Happy Monday!!! Pm me if you have any questions for quotes!!!!!
Old 07-17-2013, 07:16 PM
Happy hump day! Its almost the weekend! YES!! Pm me for the BEST deals every!!!
Quick Reply: ★★★ ARK Performance NOW @ THMotorsports!! FREE SHIP EPIC PRICING !!! ★★★
