Borg Warner Turbos
Old Jun 7, 2016 | 10:31 AM
Josh@ottp's Avatar
Borg Warner Turbos
In stock and ready to ship. Quantities are limited.
S256 extended tip with T3 outlet/.63ar $719.99 plus shipping
Borg S256 Turbo
S257 extended tip with T3 outlet/.63ar $799.99 plus shipping
Borg S257sxe FMW Turbo
Old Jun 7, 2016 | 06:58 PM
aebooth6's Avatar
What are the ratings for these turbos? What all is is needed for them to be installed correctly?
Old Jun 8, 2016 | 11:33 AM
Josh@ottp's Avatar
These are universal. They will fit a OTTP and ZZP turbo manifold and down pipe, maybe Hahn and a few others. The S256 can make ~550whp and the S257 can make ~650whp
Old Jun 8, 2016 | 01:07 PM
Bass_Waves's Avatar
At what psi does the 650 hp come into play? 32 psi
Old Jun 8, 2016 | 01:09 PM
Josh@ottp's Avatar
Right around there.
Old Jun 8, 2016 | 01:12 PM
Bass_Waves's Avatar
Originally Posted by Josh@ottp
Right around there.
Ok. I'll take a s257 right now.
07062
Pm me
Old Jun 8, 2016 | 01:14 PM
That's a really good price
Old Jun 8, 2016 | 03:25 PM
Bass_Waves's Avatar
Just joined the s257 gang. Hehe.
Old Jun 8, 2016 | 05:10 PM
aebooth6's Avatar
So I would need a new turbo manifold? That's it? I have zzps downpipe already
Old Jun 8, 2016 | 06:56 PM
Josh@ottp's Avatar
For an LNF you would need a these parts specific to these turbos. KO4 parts won't fit. Manifold, down pipe, oil feed and drain, wastegate, dump tube, bov on charge piping with maf relocate, coolant line blocked. You may be able to use your current cold air intake.
Old Jun 8, 2016 | 08:50 PM
aebooth6's Avatar
Damn for that price of all the extras it seems like the zfr would be the cheaper route.
Old Jun 8, 2016 | 09:01 PM
blueLNFftw's Avatar
It's about the Same and for a better turbo here. Not a efr turbo fan.
Old Jun 8, 2016 | 09:34 PM
aebooth6's Avatar
Not an efr fan? Why's that?
Old Jun 8, 2016 | 10:30 PM
blueLNFftw's Avatar
High fail rate and not able to be rebuilt. A super core costs almost twice as much as the kick ass deal josh is giving on the s256
Old Jun 8, 2016 | 10:38 PM
Bluelightning's Avatar
Got Bewst?
Ofcourse it gets cheaper after I just bought one. Damn.
Old Jun 8, 2016 | 11:30 PM
Sharkey's Avatar
the sxe series is a middle ground between the standard s series and the efr. it uses a billet compressor wheel and 360 degree thrust bearing from the efr. it doesnt get the fancy stuff from the efr line though, the efr still gets a stainless exhaust housing, ball bearing, titanium-aluminide exhaust wheel, built in recirc valve, options for internal wastegate. from my observations, i wouldnt say the efr is a failure prone turbo, but the s series is such a robust turbo that yes, id say the s series is a more reliable turbo. as for the efr not being rebuildable, its not that it cant be rebuilt, its the fact that because of the exotic materials used in the efr they are very tough to balance and work with, as of right now borg warner is the only ones with the proper equipment to build them. add to that, borg warner will not sell parts to rebuild them.
the shop i work with has put a number of efr turbos on, mostly on rotary engines, and they havent seen any failures yet (aside from one where the customer put cheap egt probes in the manifold, and they fell apart, on a 2 day old 9180). the difference in performance compared to an s series is huge. way faster spool times, meaning more midrange torque and power near instantly after a gear change. they have yet to try any of the sxe line, seems customers want the more budget friendly s series, or the exotic efr. cost between an sxe and efr isnt that much, and if you factor in the internal wastegate of the efr, the end result is the efr being the smarter choice.
for our world, its really depends on what your doing. on an lnf, zzp takes that generic efr and turns it into a full bolt on. this is a far better option than having to replace the turbo manifold, downpipe, purchase an external wastegate, relocate the maf, etc. somebody could do the same with an s series or sxe if they wanted, however those dont come with an internal gate option, or an internal bpv, so it makes things a lot harder and they lend themselves better to a whole kit. for all the other engines (lsj, l61, le5, lap), the s series and sxe is a great option. you already have to buy a manifold, and a downpipe. your already going to have to deal with charge pipes/locating the maf and bov, oil lines, etc. so these turbos bring the cost way down. in the end you dont have as good a performing turbo, but still is a very good turbo.
so in the end, both have their places. and btw, killer pricing on those turbos josh
Old Jun 14, 2016 | 07:20 PM
Bass_Waves's Avatar
So I ordered my turbo on the 8th. Yesterday on Monday the 13th it was at my back step. Talk about extremely fast shipping!!!!! Thanks josh. Appreciate the speedy delivery. Will return to buy more stuff later on. Literally a lot more stuff lol
315SS
Sep 18, 2016 12:51 AM
1Shotwonder
Aug 17, 2016 09:00 PM
Michealg5
Jun 1, 2016 03:46 PM
2000Firehawk
May 25, 2016 07:25 PM
Deathshead
May 19, 2016 09:50 PM
