Custom Retro-Fitting Prices and Descriptions
Here are some options for your custom headlight modifications. The prices here are "ball-park" average pricing. They could be subject to change.. Pending the type of modification done to your lights. They may be of Greater or Lesser value to that of those stated here. For full pricing on your set-up, please consult me!
LIGHT SET-UPS
This is where it all starts. With many options, it'll be hard to choose what you want!
Brand New Set of Cobalt Headlights - 175.00
Don't want to send in your headlights? Order a brand new set from me! I Use Eagle-Eyes Aftermarket "Oem-style" Headlights!
Bi-Xenon Morimoto Projectors, Choice of Shrouds, AND Clear Lenses - 150.00(H1-comes with MINI gatling gun shroud) OR 175. (D2S - any pojector of your choice.)
A 2.5" Projector that packs a mean hit! This "smaller than average" Projector is one of the best for it's price. You get to pick between a set of shrouds AND already comes with a clear lens!
This projector is up to par with the other high end projectors such as the TL/ZKW-R and FX-R bi-xenon. With barely less light out-put compared to it's other brothers.. This Projector is the best in its size class.
Uses the 2.5" clear lens that comes with FX-R bi-xenons This gives off an intensely lit beam with a sharp and colorful upper cutoff line.
Shroud Choices(included)
Gatling Gun
GTI-R
Apollo
Type One
*consider a custom finish on your shrouds to make your lights stick out that just more! For example, a color matched shroud would look great to accent your vehicle!
RetroFit Labor for Morimotos = 175.00
RetroFit Labor for Other projectors = VARIES PER PROJECTOR
*consult me for pricing
HID's
Gotta light up the road! You have a choice if you would like to run with one of the two best aftermarket HID kits on the market! I use only the best! DDM and ApexCone HID Kits!
The kits i send out if chosen by the buyer use SLIMLINE BALLASTS (extremely thin), and come in either 35watt or 55watt.
35Watt Slimline - 85.00 35Watt Slimline - D2S - 100.00
55 Watt Slimline - 95.00 55Watt Slinline - D2S - 110.00
Bi-Xenon Relay Harness - 45.00
A Bi-xenon wire harness will give you full low and high beam functionality by using an advanced relay control box. It converts to a simple plug and play harness instead of splicing tons of wire for your bixenons to function…
*HIGHLY RECOMMENDED
**This product will make your retrofit be a simple plug and play for you. Once received, just plug and play and you're good to go.
PAINT
Painting of Headlight Housings
Every car has chrome headlight housings… Why not turn that to a different color? From Black, White, to Vehicle-matched. If you want full custom even a smoked finish or anodized finish can be done(additional pricing)
Standard Black/White (Gloss or Flat) - 25.00
Color-Matched (need vehicle paint-number) - depends on GM's Pricing for paint.
Smoked/Anodized Finish/Black Chrome - 55.00
Shroud-Finishes
Want your headlight housing to stick-out more? Anodize or custom-paint-match your shroud to your car while you have a different colored housing!
Chrome - no charge
Standard Black/White (Gloss or Flat) - 5.00
Color-Matched (need vehicle paint-number) - depends on GM'S Pricing for paint. (20.00+ usually)
Smoked/Anodized Finish/Black Chrome - 20.00
CUSTOM LIGHTING
This section is what really makes your vehicle stand out! Want that "Audi R8" Look? I can do it! Want an Extremely Bright Halo? I can do that also! But wait! "What if i want that Halo or Audi-R8 style in a different color?" Bring it on i can do it!
"Audi R8 Style LED Set-up"
Based off the legendary Exotic car!
I use quality SMD LED's in this set-up, EXTREMELY BRIGHT! Can be seen in bright day-light!
Bright Laser White(standard) - 95.00
Additional colors (Red, Green, Blue, Amber) +10.00
*Ask for Limited Edition LED-Setups
"Halos"
Give your car that menacing mean look!
Quality CCFL Halos used!
Bright Laser White(standard) - 85.00
Additional colors(Red, Green, Blue, Amber, Violet) +10.00
EXTREME LIGHTING DETAILS
Want to take your headlight set-up into the next level? Look into these ONE-OF-A-KIND MODS.
"Demon-Eye-Mod"
Want your projector lens to illuminate a BRIGHT color other than that of a regular light bulb? Want to give your car the mean look of its projector resembling a glowing eye?
Look No further! This one-of-a-kind mod is done by refracting light into the proper position off the lens to illuminate the whole projector your color chosen!!! With this mod your headlights are still fully functional!
Colors to Choose: Red, Green, Blue, White, Amber - 75.00
EXOTIC COLOR: UV - 95.00 *This gives off a "Black-light" Effect. The projector ball in darkness will illuminate a purple/violet color… However, in certain conditions, if anything white or of bright fluorescent colors were to be within a few inches of the projector lens, it will glow as if in a black-light!
Custom-Shroud Lighting
Gatling Gun Shroud - "After-burner effect" - LEDs will be placed directly in the vents of this shroud to give off the effect of a Fighter-Jet Plane's Rear Thrusters! -75.00
GTI-R Shroud - "6-star effect" - individual LEDs will be drilled into place of the dimples of this shroud! - 65.00
WIRELESS REMOTE CONTROL - 65.00
Use this remote to control your LED accessories from unto 100 feet(no obstacles present)
This remote has features such as 8 levels of dimming, 5-6 strobe patterns, and "Breathing Effect"
* Great to be used with EXTREME LIGHTING DETAILS
MISCELLANEOUS:
Let's say you have everything and you just want me to put it together..
Taking apart headlight housings - 75.00
Retro-fitting projectors that you already have - starting = 125.00 - ?? (Price Varies depending the Projector)
LABOR:
ALL PROJECTS ARE UNIQUE... THEREFORE LABOR WILL BE DIFFERENT FOR EACH VEHICLE
Fine-Print - Just stating a few things to stay in the clear!
Warranty: Once Product is finished and shipped out, a 15-day warranty will be in effect. Covering Sealant issues, Craftsmanship and LED issues.
Shipping: After custom set-up is made, shipping will also be added to the sub-total. Shipping will vary by areas.
Turn-Around Time: Time varies from project to project. Once parts come in, expect 7(Mild Set-up)-14(Extreme Custom Set-up) days before shipping back, however, in some circumstances, the time may be SHORTER!
Headlight-Separation - This procedure can only be done so many times. Repetitive headlight baking takes a toll on the headlights.. Therefore i will only limit 2-3x MAX to ensure your headlight life will be prolonged. Keep this into account for customers who are sending their lights to me. If a customer sends me used lenses/headlights, they will be automatically limited to one bake session. As for warranty... If something were to happen and the headlight needs to be baked, i will only bake 2x. If for some reason the last bake should not work, we can come to an agreement on a financial situation to resolve the problem.
Pricing - Pricing may fluctuate due to supply cost. These are "ball-park" figures and help give an idea of how things will cost. Please consult me for further information!
Take your car to the next level! Fast HP, Bangin' Sounds, You've got it all! Now it's time to turn heads everywhere you go with custom headlights!
Get the attention you want, and see better at night!
Eye-Appealing AND Functional!
Have an idea for your custom set-up or want something different? Feel free to get ahold of me!
or
I can come up with a unique design to match your needs!
Get your custom set-up quoted today!
I am willing to work with each and every customer, if a certain set-up is mixed/matched and combined with other key features, it is possible we can work a small discount.
Please refer to the prices above and combine each feature with its price to get an idea of how much your set-up will cost.
The figures up-top are around ball-park, but each set-up is unique so prices MAY vary. Certain projects may require extensive modifications. Consult with me for your FINAL price.
FranciSS A.K.A. StreetRacinAzian
- Official Supporting Vendor of CobaltSS.Net!
Email - Streetracinazian@gmail.com
Cell-phone - (313)-303-6210 Text only (will reply if not busy)
Example-Project Pics:
1.blacked out-housing
2."close-style R8" LED setup
Uploaded with ImageShack.us
EXTREME Audi-style set-up
1. Blacked out Housing
2. LIMITED EDITION Audi-style LED set-up
3. Black-painted aggressive eye-lid
Custom Retrofit
1. Blacked-out housing
2. Custom GTI-R Red-Anodized finish shroud
3. Custom "6-star" LED integration on GTI-R Shroud
4. Red Demon-eye
5. Remote Controlled
*Project in Prgoress*
"They Call Me Godly's" custom headlights
1. Custom Glossy Whited-out housing
2. Limited edition Audi R8-style Strips
3. Brand new headlights
*Dynamik-iLLu51ons Custom Headlights
(side company over here in michigan by me)
1. Custom Silver metallic paint
2. Custom LED Halos
3. LIMITED EDITION multi-color Demon-Eye
LIGHT SET-UPS
Gatling Gun
GTI-R
Apollo
Type One
HID's
*HIGHLY RECOMMENDED
PAINT
Shroud-Finishes
Chrome - no charge
CUSTOM LIGHTING
"Halos"
"Demon-Eye-Mod"
MISCELLANEOUS:
LABOR:
or
Custom Retrofit
4. Red Demon-eye
2. Custom LED Halos
Not all people are educated with HIDs. So I would like to make their first HID kit purchase a good one! The price may seem stiff, but honestly I think it is priced accordingly. The quality for the price is great. When HIDs are ordered from me I pre-mount the wires to the headlight body as well as the ballast. So as that everything will be literally a simple plug-n-play for the customer.
I'd like to think my prices are fair. Other people may have access to cheaper or even more expensive kits.. But my price is set where it is at. The customer is NOT required to buy the HID kit. It is simply an option that I would like to offer them for their convenience! Therefore this is where the price is reflected from.
Thank you for your comment!
Got your PM! I will go over it and get back to you with an answer asap.
Last edited by streetracinazian; Sep 9, 2010 at 11:59 AM. Reason: Automerged Doublepost
Thank you for the suggestion! In my past, i've done a handful of lights, but there are those "warranty-huggers" who use every excuse for me to do their lights over and over..
I will try my best to reconsider a warranty-span.. But simply I do not want to be taken advantage of...
I hope you understand, but I will make an effort to reconsider.
Thank you
-Franciss!
Pm me and hopefully we can get the "ball Rollin!"
Last edited by streetracinazian; Sep 9, 2010 at 12:04 PM. Reason: Automerged Doublepost
FranciSS,
Congrats on joining the ranks of supporting vendors!
As for the comments about HID price, since he's sending them with slim ballasts, it's a fair price.
HOOK - if you work something out with FranciSS soon, I'm sure we can ship your lights to him instead, to save a step. We could even leave the lenses off if he prefers. Whatever we can do to help.
This level of custom work takes time and costs money!
FranciSS,
Thank you! Your statement shows true respect and understanding. Props on being professional and kind-hearted!
UPDATE:
will update guidlines and pricing later on today!
1. - posted more pics!
2. - plan to finish "They Call Me Godly's" headlights today!
3. i'm takin' a break lmao. see you guys in a few
