★★★ Megan EZ street and Street COILOVER SALEEE ★★★
Here we go!!! we are at it again!!!!! For those who missed out on the stance deal now we have this!
Get low! Get slammed! Handle better! For a sweet price!
DONT MISS OUT ON THIS ONE NOW! ONLY A LIMITED AMOUNT ARE IN STOCK
SUPER SPECIAL PRICING ON MEGAN EZ STREETS AND STREET!!
Megan EZ streets
Our most recent addition to our expansive coil-over kit line up, the EZ STREET coil-over line up is aimed towards the more budget oriented enthusiast to offer the most basic essentials from an after-market coil-over setup, yet makes no compromises for quality and performance.
Features:
15 Levels of Adjustable Damper Strength
Aluminum Brackets paired with rubber inserts
Rubber Dust Covers
Adjustable Ride Height
Conservative Spring Rates
Single-Cylinder Design – monotube
All coilover damper kits come with 1 year manufacture-defect warranty.
All Hardware is Included
Megan street
Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 Levels of damper force adjustment, full-height adjustment, these damper kits are then perfectly matched with front and rear Pillow Ball upper mounts for camber correction in most applications.
The adjustment of the damper is as simple as can be with a built-in knob at the top of the damper mount for easy access. Simple adjustments can be made to tune to your style of driving and comfort level desired. Single-Adjustable dampers make suspension adjustments easy to tune whether you’re a professional mechanic or an automotive enthusiast with amateur mechanical skills.
The height adjustment is made easy with CNC-Machined locking perches for accuracy and smooth adjustment. You can raise your car up to factory height for OEM appearance with performance handling or you can drop your car all the way down for a formal racetrack and an aggressive stance lowering your center of gravity to gain full potential of your car’s handling capabilities.
On most applications, the Megan Racing Damper Kits come with fully adjustable Pillow-Ball upper mounts to easily tune and adjust your camber. Adjustable camber gives you an edge on most suspension setups, as you can easily tune your car for any ride height which improves handling, predictability and furthermore tire wear, which is a great benefit both on the racetrack and on the street.
The quality and durability of the Megan Racing Damper kits are unmatched. Made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. With deformation less than 5% and high strength sophisticated surface coating, we stand by our product with our strong warranty.
Features:
Spring Rates: 10kg Front and 8kg Rear
32 Levels of Adjustable Damper
Pillow Ball Upper Mounts.
Rubber Dust Covers.
Aggressive Spring Rates
Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
Give me a call 1-800-959-0145 ext 102 Ask for Alan
Email - Acastro@thmotorsports.com
AIM - AlancTHM
Megan EZ streets
Features:
Rubber Dust Covers
Megan street
Features:
Rubber Dust Covers.
Aluminum Brackets
AIM - AlancTHM
i emailed megan racing and they said its a 3 inch drop max on the coilovers streets. my question is is the ez streets a coilover sleeve kit made for cobalts or coilovers and whats the drop on those? and i know the streets will fit a 2010 cobalt base model. but will the ez streets? and pm me a price for both kits to be bought and shipped to 02720 so i know what im looking at please.
