Over 50% Prothane Transmission Bushings & Ingalls Torque Damper!
YOU CAN BUY THE INGALLS STIFFY TORQUE DAMPER AND THE PROTHANE URETHANE FRONT & REAR TRANSMISSION BUSHINGS AS A PACKAGE FOR OVER 50% OFF NORMAL MSRP!!!
Once again, Gravana brings you a killer package promotion at a great low price! This package combines the Ingalls Stiffy Torque Damper with Prothane's Front & Rear Urethane Transmission Bushing Kits for the Cobalt SS 2.0 and Saturn Ion Redline 2.0 applications.
INGALLS STIFFY
A self-contained elastomeric shock that mounts on brackets between the engine and the chassis. It reduces extreme engine movement and dampens the motion, providing many benefits. The “Stiffy” was originally intended for the sport compact market, but can be used for some Hot Rod applications if it is applied correctly.
Benefits:
- Greatly improved off-the-line acceleration
- Reduced wheel hop
- Improved vehicle stability
- Reduced shock loads on driveline components
- Smoother shifting
- Reduced wear on exhaust system joints
- Less vibration transmission to the driver compared to polyurethane motor mounts
- Less shock load, compared to torque straps and chains
- Drifting – helps reduce shock loads when wheels gain traction
- Reduces motor movement – decreases the chance of motor parts rubbing against the hood and frame
- 1 year warranty!
PROTHANE TRANS MOUNT BUSHINGS
Much of the sloppiness in your driveline can be attributed to the factory transmission mounts. The OEM rubber mounts were never intended to take much abuse. Prothane transmission mounts are engineered to control torque and eliminate breakage. Prothane Transmission Mounts help transfer engine power more efficiently to the ground. Especially when the front & rear are used together.
Offer good only while supplies last. Not valid with any other promotions.
WE PRICE MATCH!
DANRICKARD
Oct 1, 2015 12:08 AM
