Projector Retrofit Kit - GROUP BUY!
#276
1. JoshuaVnyrd1817 (8K, White CCFL)
2. SS_NH ( 8k, white )
3. keith_AE2010 ( 6k, White halo)
4. Ryan0132 (8K, white)
5. Thesteed46 (8k, purple)
6. michiganfootball911 (6k, white halo)
7. JUICED_SS (6k, yellow halo) - PAID
8. fletchn8n (5k, white halo, 35w fogs, 5k, normal ballast) - PAID
9. Tyler1990 (6k, white halo, 35w 8000k fogs, normal ballast) - PAID
10. xnigelx (6k, yellow halo) PIAD
11. lostanfound89 (6k , white ,35w 6k fogs normal ballast) - PAID
12. CudaJoe (4300K, white halo, retrofitted projector headlight stock painted
13. Morelos704 (5000k, white halo)-PAID
14. Jhans5774 (8000k, Green Halo ) -PAID
15. Blackss185 (6000k, white halo)
16. robk (6000k blacked retrofits lamps, blue halo) - PAID
17. Falke401 (6000K, white halo)
18. RYRO14 (8000K, blue halo) - PAID
#282
Put the housing back in the oven, and then carefully pull it out.
#285
I was pulling from the back of the reflector as hard as i could. I didn't realize until i quit trying that i was cutting my fingers real bad because there are some sharp corners on the back of that thing.
#286
When your order ships, you will recieve an email through your paypal address with tracking information.
We DO NOT generate tracking numbers until your order is ready to ship. We feel doing it our way is the more accurate and honest way of doing it.
Hope that helps!
Steve
#288
Once we got the 5 we needed, everything else is a moot point, since you can just order directly from the GB page of buyhids.
#293
if something is made of plastic and you have to pull that hard then something isn't right lol. probably means you are going to break something and should look over some things to make it easier lol. plastic+force=fail lol.
#295
they were talking about the halogen reflector that sits right in front of the halogen bulb so it reflects off ot it and bounces off of the chrome housing. it's screwed into the reflector bowl.
#297
if you do remove the reflector though, I found that if you heat up those little black connector things the hold it to the housing with like...uhhh your GFs hairdryer the plastic expands a little bit and the pop off super easy. I cut the **** outa my hand removing my first ones too
#298
meh, they just pop in and out anyways. I'm not loosing sleep over it.
Hey mkulrey,
will these work on my DD - 97 civic. it has 9006 bulbs in it OEM spec
my basic instinct is telling me yes, but I just want to confirm as I'd probably pic up a set for my vtakkkk
Hey mkulrey,
