Projector Retrofit Kit - GROUP BUY!
#201
I was wondering if I could see a picture of the low beam and than a picture of the high beam to compare. Right now I have just the low beam and I hate not having the high beam.
Thanks
Thanks
#202
the ones that i got from these guys has the wires coming straight from the bulb. not a 90 deg like the stock bulbs. but in the end it dosent matter. just make sure you get a relay, dont buy the kits and then cheap out get the relay to save future head aches. top quality kits and mkulrey13 put up with all my emails of questions before i bought the fogs. great service.
I will be buysing the retro fit kit as soon as i get the ok from the wife gotta love marriage
#205
im in
im in , been loking for some headlights i like, but the retrofit is awesome
1. JoshuaVnyrd1817 (8K, White CCFL)
2. SS_NH ( 8k, white )
3. keith_AE2010 ( 6k, White halo)
4. Ryan0132 (8K, white)
5. Thesteed46 (8k, purple)
6. michiganfootball911 (6k, white halo)
7. JUICED_SS (6k, yellow halo) - PAID
8. fletchn8n (5k, white halo, 35w fogs, 5k, normal ballast) - PAID
9. Tyler1990 (6k, white halo, 35w 8000k fogs, normal ballast) - PAID
10. xnigelx (6k, yellow halo) PIAD
11. lostanfound89 (6k , white ,35w 6k fogs normal ballast) - PAID
#206
12. CudaJoe (4300K, white halo, retrofitted projector headlight stock painted.)
#208
A few questions:
It says shipping is $14.99 online, but the first page of this gb says $121 shipped...?
will the projector adjust from the stock adjustments in the back of the headlight, or do you have to do all the aiming before closing the headlight up?
Is there any bouncing of the light when going over bumps, i feel one wing nut will not hold the light steady?
What is this relay and what is it needed for, is it hard to install?
What do people hook the halo up to? a switch?
Question about headlight:
When you head it up and pull it apart, when you put it back together do you strip off all the glue and start over or can you heat it up again and stick them back to the original glue?
Anyone can answer these if they know the correct answer...
thanks guys...
thanks guys...
#211
A few questions:
you used stock aiming mounts
good question
a relay is needed if you don't want to risk the chance of damaging your wiring since the ballasts produce so much voltage - you're safe at 35w, but 55w and I would recommend a relay
they're built in automatically
Heat them up and then throw some sealant on them and place them back together and you'll be set - while using the same old sealant from GM at the same time
thanks guys...
good question
thanks guys...
#212
A few questions:
thanks guys...
thanks guys...
*Shipping Note* - USA orders for Retrofit Kits ONLY will be refunded all but 5.99 shipping fees. If you order the headlights as well, you cannot get free shipping. Canada Orders, We cannot offer free shipping at this time
You do the majority of aiming with the lights open. You can see the cutoff line in the projector, you get those as level as possible and it's usually right on. However the stock adjusters still work.
The wingnut does hold it steady, the light is very solid with no bouncing or flickering.
A relay harness gets power direct from the battery for your lights instead of going through your stock harness. It prevents HID misfires and flickering, and helps protect your stock wiring over the long run. It's a simple install.
You can choose to wire the halo to a switch or wire it to come on with your running lights or headlights.
The headlights, when you put it back together you use the same glue that's on the light, don't strip it off. We recommend using OEM sealant to make sure it's fully sealed. If you don't have that, you can use silicone, hot glue, etc, to make sure the lenses are fully sealed.
Hope that answers your questions! Thanks for the interest!
#218
how come everyone skipped me over!!!!
13. Morelos704 (5000k, white halo)-PAID
i got skipped too
#219
i got skipped too
i got skipped too
#223
So I went to add the H11 HID Kit to my cart and its saying that there is a problem with your website and it's unable to add item to cart and to contact seller... so I figured I'd let you know haha
#225
you'll have to take the lens off the headlight, then remove your factory blah blah blah, then install this kit which should bolt right in, then put the lens back on & then do the wiring.
