2.2/FE1 control arm bushing questions!
you are almost there - well leaving the poster just above alone ....you will find an awesome difference. Rides super and handles great. Do the two hole bracket its better for sure but a bit of extra work. Here is what it looks like with a second hole drilled:
thanks for the info
any other comments or suggestions?
but im confused
crate engine depot sells on the 1 hole clamp for the FE5 bar
http://www.crateenginedepot.com/stor...P2550C188.aspx
you are saying 2 hole is better and i agree with that....where do i get those clamps?
if im gunna do that im gonna get the FE5 control arms...
this rele is starting to look like a better option
1. get FE5 control arms
2. get OTTP control arm bushings
3. get eibach front sway bar or FE5 sway bar
4. get powergrid sway bar end links
and in the future
5. get SS/TC struts and shocks with pedders springs and rack spacers
since i already have the TTR rear sway bar my suspension would be completely upgraded and i wouldn't have to worry about anything any more
if i just do stock its gunna be a PITA and im gonna have to do it again in another 6 months.....
when i order the powergrid endlinks from OTTP.....would i get the cobalt or cobalt SS option if i upgrade to FE5 control arms
if i dont upgrade obviously ill choose the cobalt option
and one more question if i do opt for the FE5 control arms i can use the FE5 ones that come on the SS/TC
crateenginedepot has both FE5 control arms, the ones that came on the SS/SC and the ones that are on the SS/TC
i can use either or right?
any opinions or answers are appreciated guys :-)
and in the future
I have a LT Sedan and someone recommended switching the lower control arms (FE1) with FE5 control arms. Is this OK to do?
DANRICKARD
Oct 1, 2015 12:08 AM
