______ARK Performance DT-P/ST-P Coilover_______
Old Jan 19, 2011 | 01:55 PM
ARKracing's Avatar
ARK Performance Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 16 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for AL6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
The ARK system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process. Aeration and cavatation are a lot less common in a Monotube design, which results in a better ride. The ARK DT-P Coilover system has been designed with professional road racing in mind offering extremely high value and performance.
Features: DT-P/Track Version
- Chevrolet Cobalt 05-ON
- All bolt on system.
- 16-Level Adjustment
- Street & Track Performance Spec.
- Pillow Ball Mount / Camber adjustment (Some application)
- Mono-tube Shock design for quick reacting and quite dampening operations.
- Adjustable Ride height
- Specially designed with JDM Racing Team
- All 15months manufacture limited Warranty
(Spring Rates): Front/ 7KG/MM Rear/6KG/MM
Features: ST-P/ Street Spec
- Street Comfort Performance Spec.
- Rubber Mount
For best availability on these units please PM or call.
Also do not hesitate to contact me with any questions.
Feel free to check them out if you are local.
Email: seanpark@arkperformanceusa.com
Facility: 909)391-1275
Fax: 909)391-1276
Aim: ARKperformance86
Old Jan 21, 2011 | 02:37 PM
ARKracing's Avatar
Seanpark@arkperformanceusa.com
Fax: 909)391-1276
I am open to any questions. Do not hesitate to ask .
Old Jan 21, 2011 | 06:24 PM
Wangspeed's Avatar
I think you'll find few responses because most of these coilovers have similar construction, but slightly different spring rates and valving characteristics. There are a few things about it that instantly say not geared for track driving. The spring rates should at least be equal or higher in the back. There are 2 other major concerns that I would have, but I kind of already know the answer, so they're loaded questions.
How much droop do you have? (very, very little, which means a brutal ride over bumps)
What does the force-velocity shock dyno look like? (straight lines or progressive, unless turned all the way up. Might go slightly digressive at max. Again, brutal ride over big bumps if you tune it to proper damping at low speed)
If you really want to set yourself apart, improving the valving and spring rates, and publish the (industry standard) dyno chart. It will do wonders for you.
Honestly, I would love to be wrong.
Old Feb 3, 2011 | 02:54 PM
ARKracing's Avatar
^^^ Wsup Wang
Appologies for the late response. It seems as though we should have subscribed to this thread.
Our Dt-P and St-P coilovers have a 16 level height adjustment, So drop rate is nearly unlimited.
From fully slammed to monster truck height. LOL . Appologies I have never seen a race track with speed bumps..
Also the difference in spring rates from front to rear is all personal prefernce. Our Street spec and Track spec are dyno proven and track tested.
I may have some shock dyno's, I will be sure to post them up once I have looked through my files.
Let me know if you have any more questions Wang.
Thanks.
Old Feb 3, 2011 | 02:56 PM
ARKracing's Avatar
2 sets gone this week.
Still blowing them out!!!!
PM or call for pricing or availability!!!!
Email: Seanpark@arkperformanceusa.com
Facility: 909) 391-1275
Fax: 909)391-1276
Old Feb 3, 2011 | 03:05 PM
Godly's Avatar
Priceeeeee????????
Old Feb 3, 2011 | 03:35 PM
Wangspeed's Avatar
Originally Posted by ARKracing
^^^ Wsup Wang
Both low speed and high speed damping are important anywhere. Racetracks are no exception. The low speed stuff is what controls the "handling" feel, like body roll. Bumps, undulations in the pavement, apex/track out curbing, etc are all high speed damping. Since you're selling suspension, I would think that it would be critical to educate yourself in this.
The shock dyno for this application will tell the tale. If you would post them, that would be great. Thanks.
Old Feb 3, 2011 | 08:31 PM
ARKracing's Avatar
Agreed.
First thing people picture in there head when they hear race track is FAST!!!
Track driving consists of alternating from high to low speeds constantly. Especially when cornering, which is why a good compression and rebound setting is very important. Thanks
Old Feb 3, 2011 | 08:33 PM
ARKracing's Avatar
We have done shock dynos for the 350z application to do some fine tuning with its application. We have close ties in with an independent shock company that does all the dynos for us.
Please use this as reference for now, and we will provide you the actual dyno for the cobalt Models as times progress
Our ARK Performance z33/350z coilover set up are somewhat comparible to the cobalts.
Spring rates of z33/350z Dt-P Track version is F 12 kg/mm R 11KG/MM
Old Feb 4, 2011 | 12:12 AM
Wangspeed's Avatar
I think it's admirable that you guys are open to posting information about your products. However, those graphs confirm what I was saying earlier. Looks pretty much linear for rebound and kind of digressive for compression. Unfortunately, most shocks of this construction have very similar dyno curves. Like I mentioned before, the spring rates also need to be higher in the rear for a high performance application.
Thanks for posting the info. It's much appreciated. Would be better if it was for the Cobalt app, but this gives us an idea what to expect.
Old Feb 4, 2011 | 12:17 PM
ARKracing's Avatar
^^^ no problem.
Will post up once we dyno the cobalt apps.
Old Mar 14, 2011 | 03:41 PM
ARKracing's Avatar
Thanks for everyone who inquried about these coilovers over the weekend.
2 sets shipped today. Last Call. Thanks
Old Mar 14, 2011 | 11:37 PM
BlueBalt1113's Avatar
price?
Old Mar 16, 2011 | 07:36 PM
ARKracing's Avatar
Pm Sent. Thanks
Still blowing them out!!! PM por call in for availability.
Old Mar 21, 2011 | 03:48 PM
ARKracing's Avatar
Bump Bump
Old Mar 24, 2011 | 12:49 PM
ARKracing's Avatar
Keep the Pm's Coming! Thanks!
Old Mar 29, 2011 | 03:25 PM
ARKracing's Avatar
Bump Bump 2 of each STP and DTP!!!
Old Mar 29, 2011 | 07:57 PM
06cobalt racer's Avatar
i have been running a set of the dt-p ones for a year now. i love them!!!
Old Mar 30, 2011 | 03:43 PM
Projekt's Avatar
PM price please
Old Mar 30, 2011 | 04:07 PM
ARKracing's Avatar
Thanks for the comment!
Both sets available!
Old Mar 30, 2011 | 04:09 PM
ARKracing's Avatar
All Pm's Replied. Keep them coming!!! Call in for tracking numbers. Thanks
909)391-1275 - Office.
-Team ARK
Old Apr 4, 2011 | 12:11 PM
ARKracing's Avatar
Thanks for the orders over the Weekend.
All pm's replied. 1 set shipped today!
Old Apr 7, 2011 | 08:51 PM
ARKracing's Avatar
Keep the Pm's coming.
If you did not receive an automated email with your tracking number.
Please call in and ask for Sean. Thanks.
909)391-1275
Old Apr 14, 2011 | 04:50 PM
ARKracing's Avatar
1 set of STP's shipped today. Hurry before your too late.
Old Apr 17, 2011 | 12:21 AM
BooSSted's Avatar
Price?
