ABS Warning light
ABS Warning light
hi there.
I have a '06 SS/SC.
Last night I was testing my car a little bit, I just got my exedy hyper single installed so I was kind of trying it out a little bit.
Well I was trying to launch the car from about 2500rpm when the car suddenly jumped out of the first gear and that same moment the Abs warning light came on.. So I drove it just a little bit till I could find some place where I could stop and check it out . The car drove perfectly and I didn't feel anything wierd when I tried using the brake.
So then I stop turned the car off and I tried to see if I could see anything, but I couldn't see anything. Then started the car back on and some that the ABS warning light wasn't on anymore..
Today I drove the car without any problems.
I'd like to know what you guys think about it.
Thanks
I have a '06 SS/SC.
Thanks
i dunno. electrical systems are funny that way. you do one thing that seems completely unrelavent and you think that thats what caused it but really it just happened to happen because at that particular time the other issue was bad enough to set the light. get the code and it will tell you more
My ABS light is on right now also. I think it must be a loose or corroded sensor plug. They are in behind the front rotors. I have unplugged mine a couple of times while swapping springs, but have always made sure to plug them in again. The ABS has been kicking in really easily recently also. I'm going to inspect and clean the connectors when I put my summer wheels on. Is there a special cleaner/anti-corrosion spray available for electronic connectors?
z28addiction
Sep 28, 2015 12:03 AM
