adding rear sway bar question
Old Aug 6, 2010 | 03:31 PM
bigmd's Avatar
I have an 07 2.4.currently I don't have a rear sway bar.I plan on buying the eibach bar.what's involved with the install?does it come with everything I need?
Old Aug 6, 2010 | 03:37 PM
northvibe's Avatar
you should go to ottp and order the Street rear sway bar.
Install consists of laying under car, bolting bar with 4 bolts and being done. You need a wrench or socket.
Old Aug 6, 2010 | 03:42 PM
bigmd's Avatar
Whats the difference between the two bars?
Old Aug 6, 2010 | 03:47 PM
northvibe's Avatar
the ottp is made by Powell raceshop, the same shop that made the time attack SS and its rear sway bar. That bar is smaller than the time attacks but its made to work the same. The eibach is smaller and a solid piece I think. The race shop bar can also come in different colors and is of high quality. I have the hardcore version which is even thicker (hallow as well) but I recommend that for only people that will actually autox or race on a road course.
Old Aug 6, 2010 | 03:58 PM
JL-KA's Avatar
He's a powell groupie...don't mind him
Either bar is going to be good. Install is super easy for the rear...front...not so much.
Definitly a good mod. It really helps handling.
Old Aug 6, 2010 | 04:21 PM
bigmd's Avatar
Thanks .gonna be adding eibach pro kit and new strut and shocks
Old Aug 6, 2010 | 04:28 PM
dayhoff35's Avatar
i have a ttr one ill sell you with everything you need to install it for 115 shipped it took me like 20 minutes to install it all you have to do is bolt it on
Old Aug 6, 2010 | 04:33 PM
ericgt79's Avatar
whats the difference in the street rear bar vs. the eibach front+rear kit...
to me right now the diff is 200+ for one bar vs. 300 for both front and rears.
Old Aug 6, 2010 | 04:41 PM
northvibe's Avatar
All the OP has to do is read around as to why its the better choice...
https://www.cobaltss.net/forums/suspension-67/thoughts-rear-twisting-beam-sway-bars-202507/
https://www.cobaltss.net/forums/suspension-67/thoughts-cobalt-front-suspension-202915/
Old Aug 6, 2010 | 07:04 PM
JL-KA's Avatar
and how many beers??? cuz it took me less than 5.
Originally Posted by northvibe
Eibach is heat treated...not mild steel like TTR.
Quick said right in the thread you posted that properly heat treated bars are good.
I have the TTR and have had it since back when there was no OTTP bar or Eibach bar. Mine is still it's original shape. But this isn't about them it's about Eibach and OTTP. BOTH are good bars. It just depends on what you intend to do with them. Nobody has ever argued that. No need to start now.
Old Aug 6, 2010 | 08:54 PM
northvibe's Avatar
I never argued. I stated my opinion on which bar to get.
Old Aug 8, 2010 | 11:14 AM
FraGmE's Avatar
put the 22mm progress bar on mine last week. super easy install and the handling is amazing.
Old Aug 10, 2010 | 02:16 PM
KoriCobalt's Avatar
Just installed my Eibach front and rear sway bars yesterday. The rear was a tough decision I was debating between Ottp and Eibach but I went with a set instead. There both great sways in my opinon, need to go to an autocross sometime now.
brandon04
Oct 21, 2015 07:04 AM
DANRICKARD
Oct 1, 2015 12:08 AM
Delta coupe
Sep 30, 2015 08:11 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
