Alignment Help Please!
Old Oct 18, 2007 | 12:43 AM
116Fanatic's Avatar
So I just got my 06 2.4 used and it pulls a very decent amount to the right. I raced my friend and almost slammed him cuz punching it threw it to the right. So i figured, I need an alignment right? Then I read this...
"If the camber is different from side to side it can cause a pulling problem. The vehicle will pull to the side with the more positive camber. On many front-wheel-drive vehicles, camber is not adjustable. If the camber is out on these cars, it indicates that something is worn or bent, possibly from an accident and must be repaired or replaced."
http://www.familycar.com/Alignment.htm
Any ideas or help please?
Old Oct 18, 2007 | 12:49 AM
HunterKiller89's Avatar
if it only pulls under WOT then its probably just TQ steer, but if it pulls when just cruising or idling, then yea, you got an alignment problem.
if it is the alignment, go get your car aligned professionally, and if need be, they have adjustable camber pieces to help out as well, and theyre pretty cheap
Old Oct 18, 2007 | 12:52 AM
116Fanatic's Avatar
Oh...so that article lied that its not alignable then? It is under normal cruising, so I'll have to get an alignment. Gracia, +rep
Old Oct 18, 2007 | 01:51 AM
it does say "many" cars, and i think ours are adjustable stock, and if not, there are camber kits that allow adjusting from +/-3 degrees
and NP, +rep back at ya
TotalChaos
Oct 14, 2015 06:49 PM
DANRICKARD
Oct 1, 2015 12:08 AM
CobaltSS 16
Sep 12, 2015 02:43 PM
ROADKONE
Sep 9, 2015 02:32 PM
DisJuan
Sep 7, 2015 04:24 PM
