alignmnet while lowered
So i go to a tire choice to get my alignment done. i mention to the guy that i am lowered. he told me that the alignment wont stay and will always go off since im lowered..is this true or is this bullshit?
i know omg.....im getting a alignment as i type this, he told me it wont stay and im going to have to keep payign for alignemnt...
Alignment should stay long enough to get you through a set of tires, assuming you don't drive through major pot holes for sport. If you notice any pulling or uneven tire wear it's good to get it checked.
He's bullshitting you unless like the previous poster has said if you enjoy going pothole hunting.
Avoid the big bumps and if you have poor road conditions or you take driveways too fast you may end up having to get another one but it will take more than 20-30k before you do.
Also, I waited 3 full weeks of driving/sitting/using the vehicle before I got the alignment done to allow the springs to settle otherwise, you will have to have it redone when they truly settle for good. I hope you got the lifetime alignment package!
guy is feeding you bs, i work at a dealer and have done many alignments, as said, as long as you miss holes, hard bumps, ect. and let the springs settle itl last you the life of the tire. anytime ride height is changed or any component in the suspension is changed a alignment is necessary. now if you get a alignment by him and without hitting anything and easy driving it begins to pull/ drift or whathave you, he has left something loose or done somthing to make even the slightest pebble in the road change it so that you will continue to need a alignment
