anti-sway bars
Old Apr 28, 2008 | 11:07 AM
Shaun927's Avatar
anti-sway bars
i was looking at anti-sway bars and wondering which one would be the best one to go with b/w progress and turbo-tech or any other company if theres something better ?
Old Apr 28, 2008 | 11:09 AM
BOOSSTED 06's Avatar
those two are identical sway bars, TTR is same design just thicker so go TTR
umrdyldo's Avatar
Well according the TTR their bar is much more rigid due to it being bigger.
I installed mine this weekend and it's great. Trust me easy install and works great.
Go for it. Cheap group buy hurry up.
Old Apr 28, 2008 | 11:14 AM
Shaun927's Avatar
alright turbo-tech its is thanks guys
Old Apr 28, 2008 | 11:46 AM
TurboTechRacing's Avatar
We have 9 black and 5 red in stock, order soon as we will run low on stock by the end of the week.
Old Apr 28, 2008 | 12:01 PM
Shaun927's Avatar
im ordering the the anti-sway bar and the tranny mounts but the discount code TTR1001010 isn't working
Old Apr 28, 2008 | 12:58 PM
REMINDER:
Pre Sale (Discount) stopped this past Friday 4/25/08 as it was stated. They are no longer on pre sale, as they are now shipping (In stock), no discounts are avaliable any longer...
Old Apr 28, 2008 | 04:05 PM
joeyblaze's Avatar
i hear the aftermarket rear sway bars dont reduce body roll, they just make the car more tail happy, is this true?
Old Apr 28, 2008 | 04:15 PM
umrdyldo's Avatar
Tail happy?
Pretty sure they reduce roll. Put one on and see.
Old Apr 28, 2008 | 04:18 PM
INFE's Avatar
It made my car more controllable and made the rear much stiff so you dont get that sloppy feel anymore.
Old Apr 28, 2008 | 04:24 PM
Pickles's Avatar
But will the bar make it easy to slide the rear end of the car? I have heard discussion of this rumor as well...
Old Apr 28, 2008 | 04:28 PM
OrngBalt's Avatar
no it wont.
Old Apr 28, 2008 | 04:35 PM
umrdyldo's Avatar
I doubt you will slide the rear if you don't have rear wheel drive breaking the car loose. I don't think it can take that much pressure off the outside tire while cornering. Just enought to turn better.
Old Apr 28, 2008 | 05:02 PM
joeyblaze's Avatar
it will infact make the rear roll less then front which in theory should reduce the amount of understeer and make the car oversteer more, hence i said does it make the car tail happy. if it does infact just reduce roll in the back it should make the car lean more towards oversteer.
Old May 1, 2008 | 09:13 PM
Apcsox's Avatar
the Turbo Tech Racing... look in the supporting vendor group buys forums........ you will not be disappointed!
Old May 1, 2008 | 09:14 PM
xravenwingsx's Avatar
I'm very happy with my Progress anti-sway bar. had it a year and a half now...no complaints
Old May 1, 2008 | 10:17 PM
maverick0716's Avatar
I don't really know of a single FWD car that has oversteer......they all understeer in my opinion.
Old May 2, 2008 | 02:09 PM
qwikredline's Avatar
right on maverick! 100%. However in fact by stiffening the rear, (how much is an issue) you will make the car become more and more sensitive to gas on understeer gas off oversteer...gas on push, gas off loose...too much rear stiffness and the car maybecome difficult in the rain as you come off the gas and turn into the corner. At the end of the day until the floppy twisting pivot beam bushings are replaced with spherical joints, the car can never get to where it needs to be for the track. Stock is fine for the street...
Old May 2, 2008 | 04:49 PM
INFE's Avatar
i feel i gave the car a more neutral feel, even in the rain. It does not oversteer. Its a FWD I wish the rear would come out alittle! Belive me i tryed
Old May 2, 2008 | 05:05 PM
Sounds like everyone is happy
More are in stock at www.TurboTechRacing.com
Old May 2, 2008 | 06:46 PM
YSUsteven's Avatar
I agree
It might slide the rear if your driving in snow, otherwise no.
Only slides in snow.
This is true.
That is because the front wheels pull the car, and that they are usually nose heavy from engine and trans.
It will only start to come around in the snow. Otherwise, its great.
Old May 4, 2008 | 11:59 AM
Very Nice.
Solaris99
28
Mar 15, 2017 01:22 PM
SSLOW06
Oct 1, 2015 07:21 PM
DANRICKARD
Oct 1, 2015 12:08 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
