ARK Performance INC Cobalt SS/SC GTF Lowering Springs
Old Apr 25, 2011 | 11:08 PM
  #76
Ch1ck3n's Avatar
Took the 'Balt out for a pretty hard run today on an 8 mile stretch of back country road with close to 50 turns chicanes and undulations. It was still a little too cold for my summer tires, but I felt more confident in the turns without the body roll, and the handling was exactly the same as stock if not better (plus I had my 185lb roommate in the car with me). I'll post pics of the drop sooner or later.
Old Apr 26, 2011 | 12:40 AM
  #77
Rodimus_Prime's Avatar
how these compare to eibach sportlines?
Old Apr 26, 2011 | 12:25 PM
  #78
ARKracing's Avatar
Thanks for the great review!
Glad you are enjoying your ARK springs!
Old Apr 26, 2011 | 12:27 PM
  #79
ARKracing's Avatar
These are very comparable with eibach sportlines.
You can read the mini reviews above where they are compared.
Still blowing them out! quantity very low!
Feel free to contact me for any questions, or availability.
Email: Seanpark@arkperformanceusa.com
Facility: 909)391-1275
Fax: 909)391-1276
Aim: ARKperformance86
Old Apr 26, 2011 | 08:56 PM
  #80
Ch1ck3n's Avatar
Here's a picture of the drop in the rear.. I looked at it and all I could say was holy ****.
Tuckin tire on springs.
Old Apr 29, 2011 | 03:40 PM
  #81
ARKracing's Avatar
^^^ Sweet!
Bump for 2 sets remaining!
Old May 4, 2011 | 02:02 PM
  #82
ARKracing's Avatar
Last Call for ARK Performance GT-f Drop springs!
Old May 18, 2011 | 02:11 AM
  #83
ronn's Avatar
Originally Posted by ARKracing
Sorry for the late reply. Maybe I should have subscribed to this thread.
As far as spring rates there really isnt an actually number I can give you on
Lowering springs; because it is a progressive spring....
Hear is our specs of compression. Although everyone drives differently.
Front: 115 - 200 lbs/per inch.
Rears 50 -180 lbs/ per inch.
Thought I'd provide info for stock TC spring rates.
Front: Linear 154 Lbs (27 N/mm)
Rear: Progressive 160-228 lbs (28-40N/mm)
The MacPherson strut independent front suspension uses SS-specific gas-charged twin-tube struts; unique steering knuckles with optimized geometry; 27 N/mm linear coil springs with specific damper tuning; stiffer control arm handling and stabilizer bar bushings; and a direct-acting, 24-mm solid stabilizer bar. At the rear, the SS’s semi-trailing twist beam axle uses monotube gas-charged shocks with specific damper tuning, a 24-mm solid stabilizer bar, stiffer axle bushings and multi-rate coil springs (28-40 N/mm). StabiliTrak electronic stability control and traction control are standard
Old May 18, 2011 | 02:21 AM
  #84
ronn's Avatar
Installed these springs last Thursday on my LNF. The ride feels only a tiny bit bumpier than stock, handles amazing (read a 1.02 lateral g on the RPD with only minimal tire slip). Just enough body roll that it's not painful. Did 130 with total confidence. So far, they seem awesome and are such a difference from stock.
As the springs settled, I have about 2 fingers distance between the tire and the fender (stock ss/tc wheels with 235/40/18's). Some rubbing issues in the front when turning to lock, but nothing while driving. I'll take some pics shortly.
See my previous post on TC rates. These are about stock spring rate on front, but MUCH softer in the rear. You want the STIFFER rear vs front this car..these are softer rear vs front.
Old May 18, 2011 | 02:31 AM
  #85
ronn's Avatar
Originally Posted by ch1ck3n
here's a picture of the drop in the rear.. I looked at it and all i could say was holy ****.
too low!
Old May 18, 2011 | 11:50 AM
  #86
Wangspeed's Avatar
Originally Posted by ronn
too low!
Agreed. Too low, and too soft. But I guess if you don't care about handling, or banging the exhaust against the beam, it's fine...
Old May 18, 2011 | 01:31 PM
  #87
ARKracing's Avatar
Drop rates on the our GTF springs. Front / Rear: -35mm/-40mm
Haven't had any issues with exhaust piping coming into contact with the rear beam
with all spec models.. products have been tested rigorously during the R and D process several years back .
Thanks!
Old May 18, 2011 | 04:17 PM
  #88
ronn's Avatar
Thanks!
These were really designed with 05-07 cobalts on mind..not TCs which have stock spring rates that 20% higher. From the pic of the TC rear here, these springs are not desireable. Perhaps the other type springs you offer (less drop) would be better for the TC?
Old Jul 11, 2011 | 07:12 PM
  #89
ARKracing's Avatar
good in stock!
Old Jul 17, 2011 | 12:42 PM
  #90
ford's Avatar
Ordered mine on Friday. Can't wait to give a review, ark makes nice stuff and i suspect nothing less from their springs.
Old Jul 17, 2011 | 01:05 PM
  #91
RHZ's Avatar
RHZ
I've had them for about a year on my TC and they're great. Handle like a dream and look great. My only gripe: Tires rub a lot in the rear when i have a rear seat passenger and i rolled. But i still wouldn't switch to any other spring.
Old Jul 17, 2011 | 01:07 PM
  #92
RHZ's Avatar
RHZ
Old Jul 17, 2011 | 01:20 PM
  #93
Dayta's Avatar
hmmm... thats a wicked clean drop
Old Jul 17, 2011 | 01:31 PM
  #94
ford's Avatar
Damn they are lower than that pic of the ss/sc. RHZ your car looks good. The silver balt is a lil too low for me but ill see how mine drops by the end of this week.
Old Aug 4, 2011 | 11:23 PM
  #95
AARON-SS-TC's Avatar
i think that silver ss looks good slammed.
why is it lower than the black one?
if they would lower my car like the silver one, im wanting them. I guess at 30k miles i would need new struts as well
Old Aug 5, 2011 | 09:43 AM
  #96
RHZ's Avatar
RHZ
I'm at 44k, about half of that has been lowered. My struts are still perfect.
Old Aug 11, 2011 | 07:43 PM
  #97
ARKracing's Avatar
Everyone's pictures look amazing with there new stance.
Congrats! Keep us posted with any reviews or pictures.
ARK GTF- Springs are well in stock, and are being blown out!
Old Aug 17, 2011 | 01:10 PM
  #98
apparently, b&g springs are blowing struts prematurely, so I am in for these..
No Gt-s springs for the Cobalt ss-tc, just Gt-f model correct?
Old Aug 17, 2011 | 03:25 PM
  #99
RHZ's Avatar
RHZ
They are just called ARK GT springs. GT-F(ront) GT-R(ear) you get both when you order the ARK GT springs for the cobalt.
Old Sep 22, 2011 | 06:29 PM
  #100
bspeed's Avatar
bump how much are these springs?? their site is fucked up are they a decent deal>? looks low and exactly what I'm looking for
