Auto-X
Old Mar 8, 2008 | 09:54 PM
Dunkinuts's Avatar
Auto-X
what would be a good set up for road racing and auto-x?
tires:
wheels:
springs:
shocks:
coilovers:
brake pads:
brake disc:
brake lines:
sway bar:
strut bar:
etc:
Old Mar 8, 2008 | 09:57 PM
hatrickstu's Avatar
im sure you are going to get a wide variey of answers on this. but if you are planning on running a coilover system, then you dont need shocks and springs on the list
Old Mar 8, 2008 | 09:59 PM
Dunkinuts's Avatar
true but i put them both on incase some one wants shocks and springs vs coilovers, i mean the Koni shocks and some nice springs seems like a good combo, but i don't know all that much when it comes to suspension companies.
Old Mar 8, 2008 | 10:06 PM
rallyracer's Avatar
tires: Competition grade (check tirerack.com)
wheels: 17" light weight (check out the group buys on css.net)
springs: Eibach Pro-kit
shocks: Koni
brake pads: Hawk HP Plus
brake disc: Stop Tech
brake lines: Garden Hoses
sway bar: Unk
strut bar: TTR, soon to be released
Old Mar 8, 2008 | 10:35 PM
Dunkinuts's Avatar
rallyracer have you used the Koni shocks? are they any good? are they "hurt" with lowering springs?
Old Mar 8, 2008 | 10:37 PM
redlineblueline's Avatar
shocks: Koni
sway bar: Eibach
dont and probably wont ever exist
Old Mar 8, 2008 | 11:23 PM
qwikredline's Avatar
Thumbs up
tires:hoosier a6
wheels: ccw
springs: oem ss s/c
shocks: oem ss s/c
coilovers: no
brake pads: cobalt or pagid
brake disc: oem
brake lines: earls/goodrich
sway bar: oem fr /time attack rear
strut bar: none
etc:
lose weight /aftermarket h.e/dual pass/remote fill/stage 2/lose weight/corsa exhaust/flca mod lose weright, see GM Grand Am build book
Old Mar 9, 2008 | 10:48 AM
Switt23's Avatar
Koni's were designed for the purpose of lowering. The strut shaft has been shortened and re-valved so it will not bottom out as easy. They are adjustable for stiffer or softer ride.
I'd recommend them to anyone who is lowering or auto-x ing.
the only thing you need to worry about!!! Some things you put on the car will put you into a new class. You need to decide if that part is worth the class jump becuase in some cases you'll be up against AWD Subarus and the like that you'll have no chance against.... I think you should just take that into consideration if your gunna auto-x
Old Mar 9, 2008 | 11:08 AM
alleycat58's Avatar
tires: depends on how much you want to spend - r-compound competition tires are the best
wheels: no larger than 16" and as light as you can find them
springs: depends on where you live. i can't really do anything with springs myself because of the area where I live, but you may be able to go with Sportlines or at least the ProKit from Eibach
shocks: Konis. Period. That's if you don't go coilover.
coilovers: Obviously the best option out there would be adjustable coilovers.
brake pads: Hawk HPS
brake disc: Stock OEM blanks or Brembro blanks. For performance driving DO NOT fall into the drilled/slotted trap - that's the worst thing you can put on your car.
brake lines: stainless steel all around. Should be one of if not the first mod you do.
sway bar: Go larger front and back. A lot of cars do better with a smaller front or a front delete and larger back. After a lot of runs and expert opinions, the SS/SC needs a larger/stiffer bar up front.
strut bar: MRZ front strut bar, their design should be slightly more rigid than the DC sports design.
etc:
Yes, research this first. If you've got an SS/SC - my reccomendation is to either stay in stock class (DS) or run in our Street Prepared class (CSP). If you get caught in STX or SM you're going to get eaten alive by MUCH faster cars.
Old Mar 9, 2008 | 12:09 PM
Dunkinuts's Avatar
well i wouldn't really be out there to win at first, mainly just to have fun. but from what i am getting a good set up would be
tires: Bridgestone Expedia S-01 ($436)
wheels: stock
springs: H&R Race Spring Set ($226)
shocks: Koni Sport Cartridge ($652)
brake pads: Hawk HPS ($126)
brake disc: stock
brake lines: Goodridge G-Stop Brakeline Kit ($115)
sway bar: stock
strut bar: stock
so for just over $1500 I would have a pretty good set up. and would that put me into a class that I would get bent over in? since it would be my first time doing any kind of auto-x. also I drive a '08 Sport (2.4L/5-spd)
Old Mar 9, 2008 | 12:30 PM
alleycat58's Avatar
In a 2.4 you should be OK. The springs will bump you into STS, so throw on an intake and exhaust and you will be OK.
Old Mar 9, 2008 | 05:05 PM
Dunkinuts's Avatar
so do you think i need to upgrade sway bars?
Old Mar 9, 2008 | 06:00 PM
alleycat58's Avatar
Do the rear at the bare minimum. The SS/SC would benefit from a larger front, and the 2.4's sway bar is smaller still, but that mod is a real pain in the ass to do so I would hold off on it until you're more experienced.
Old Mar 9, 2008 | 06:11 PM
Sharkey's Avatar
id say take the car out and play with it in the stock class and learn to drive first (no disrespect, it takes a while to get it down). only do mods that allow you to stay in the class you plan to run, once you get bored of that class then move up and do some more mods.
one big issue with the cobalts and autocrossing is the steering knuckles, they tend to break around the hub when under the stresses of autocrossing/road racing, and when they break they can cause some serious damage. gm does have a performance steering knuckle avalible to fix this issue, the only problem is if you put them in you cant run is stock (its all because the word performance, if they used the word "heavy duty steering knuckle" it would be ok)
Old Mar 9, 2008 | 06:52 PM
Dunkinuts's Avatar
well i am looking at maybe two or three track day/auto-x trips a year. i don't think i will get to the point of needed know steering knuckles. thanks for the heads up. but what sway bar should i look into? i know the eibach (rear) is hollow and i am not a fan of that.
Old Mar 9, 2008 | 06:54 PM
rallyracer's Avatar
how much is the steering knuckle?
Old Mar 9, 2008 | 07:02 PM
the eibach doesnt exist
Old Mar 9, 2008 | 08:05 PM
alleycat58's Avatar
I have the progress rear.
They'er a little over $300/each from CED now.
Old Mar 9, 2008 | 11:18 PM
Dunkinuts's Avatar
how likely are the steering knuckles to break? i have never heard of anyone breaking them.....
Old Mar 10, 2008 | 05:52 AM
alleycat58's Avatar
Heh. I can think of at least 7 people I've seen on here and that I know in person who have had them break just with normal street driving. Hence why I'm not comfortable taking anymore chances with mine. Auto-x I'm not too concerned about, but if I break one out on a road course at 140+......the car is totaled and I may be too. Put it this way, $600 is way less than the damage you'd be repairing if you were to break one.
Old Mar 10, 2008 | 02:49 PM
rallyracer's Avatar
I thought they were around $300.00?
Also, where on CED site can I find these?
Old Mar 10, 2008 | 03:05 PM
alleycat58's Avatar
$300 and you need one for each side.
Right
Left
Old Mar 12, 2008 | 10:40 PM
i gotta say that the steering knuckle will only break if you hit something with it...say a curb or another car, hard. In normal auto x its fine.
the only broken ones i have seen are in crashes...not to say it cant happen, but i wouldnt spend a dime on knuckles if I were you. By the way it is a Pontiac G6 part, with a machined steering arm for correct steering arm height and lower ball joint hole drilled to take untapered ball joint.
Whoever said: "In fact, you’re more likely to win the lottery while being struck by lightning during a shark attack." than break a knuckle.
Whoever said you should run the car straight up and learn said it right. BTW i tried Konis once. They are shorter. So you lose ride travel. what does that mean? Car goes around corners lifiting inside wheels like a dog at a hydrant...ugly....maybe they have changed by now, who knows? Stay stock SS/SC and be happy...
Old Mar 13, 2008 | 10:41 AM
Dunkinuts's Avatar
2.4L sport here
but i am going to leave it stock for the time being but i wanted to know for future purchasing.
1WhiteSSTC
Autocross and Road Racing
Dec 9, 2008 09:14 PM
