ball joint question
Old Mar 10, 2013 | 11:21 PM
LP08SS's Avatar
ball joint question
hey guys ive got an 08 SS and i recently replaced the ball joints and CABs with moog components. i took the car for a test ride and the steering felt a little funky so i took it back home and jacked it up to do a double check. drivers side checked out OK when i got to the pass. side i noticed that the steering knuckle was loose around the ball joint pin so naturally i went to re-torque the pinch bolt, strange part is that it was properly torqued yet the fit is still loose. so my question is could i have been sent a wrong ball joint (FE1 or FE3 instead of the proper FE5) or some how could my steering knuckle have sustained enough abuse to actually widen the hole that the ball joint mounts into? any input would be greatly appreciated!
Old Mar 10, 2013 | 11:32 PM
In for answers, sadly im of no help
Old Mar 16, 2013 | 01:18 AM
LP08SS's Avatar
Old Mar 16, 2013 | 09:38 AM
emiller's Avatar
Measure the ball joint stud sizes and compare. The lnf fe5 is larger than the rest.
Solaris99
28
Mar 15, 2017 01:22 PM
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
