Brake question
Brake question
So I was trying to have a spirited drive down a well known twisty road when some old man in a new craze hatch was having a Sunday drive down this road. So I would go ridiculously slow so I could get some distance and enjoy the bends. The thing is I have an 07 base model with no abs and I swapped out the rear drums to discs and I got the lab front brakes. So this guy decides he will be a dick and brake check me so I Slam the brakes and all I hear is screeching tires from me.
So I'm wondering if I did something wrong in the swap(had it for almost a year now) or if it was just the dry sandy patch of road that this dick chose to brake check coupled with me slamming the brakes. Noob question I know but I've been driving the car for 2 years and never encountered that. I'm also on winters as well.
the important thing to note is what wheels locked up, front or rear. in a non abs brake system the fronts should lockup just before the rears do. if the rears lock up first you are at a higher risk of losing control
im not familiar with the rear disc swap, but is anything changed for proportioning when the swap is done? pressure/volume for a disc setup is different from a drum.
I'm guessing it was definitely rears first. Like y'all have said without adjusting the proportioning the drum setup will have waaaayy to much clamping force in the rear relative to the old drums.
But I swapped the beam, brakes and hubs all around with a 2006 lsj ss. Just put the stuff on and bled the brakes. Was unaware of any bias adjustment! How do I go about doing it?
Yes I'll admit I was coming up quickly but that's no reason to slam the brakes. I wasn't riding his ass, just going around corners and catching back up to him. I don't really see where me driving a car length behind your car for less than 30 seconds warrants potentially wrecking both cars just because you want to puff up your feathers. Brake checking is stupid and far more dickish than driving close to somebody on a twisty road.
Maybe not enough reason to brake check but you're not innocent here.
Was never saying I was. This post was 1 part rant 2 parts hoping I did my swap right so I don't end up in the back of another car in an emergency.
