Brembo Swap LSJ
Completed front brembo swap on my 07 LSJ
Test fit with ion redline wheels
Spacers used sabb eibach hub centric
Studs used 2000 camaro overlength
Simple bolt on but makes a big difference
bout 500.00 with new rotors and pads and used low mileage calipers
yup big difference, i was used to slowing into stop now its more of light tap and your flying into the windshield
Rotors- P# 15893541 (left and right)
Brembo Calipers- FRONT LEFT P #25900763 FRONT RIGHT P# 25900764
pin kit- P#25900781
pad kit - P# 25808929
Eibach 15mm 90.2.15.007.1
Studs Napa- BK 6411581
new copper seals
pin kit- P#25900781
new copper seals
if you gonna spend like a grand you could get those after piston brakes. i give you the link.
i would love brembo's tho. nice job on the swap
http://www.tceperformanceproducts.co...s.pl?record=27
or ssbc brake kits
or ssbc brake kits
or ssbc brake kits
or ssbc brake kits
Prob. will upgrade when i could come across the tc set up, or may just upgrade the rears with aftermarket pads and rotos, for now it's fine for me, btw HHR SS uses the same Brembo components
Thanks for the plug. And I'd agree that for someone who has access to the factory parts at a reasonable cost. For those who don't want to spend time with both parts searching and fumbling around with more parts change than necessary the BBKs already fit for the car can make things both simpler and quicker. The need for a wheel spacer is interesting...was this because the oe wheel for the factory Brembo is not the same wheel on the ss now?
It's tough to compete at the $1000 price point for true big brake kit items. Taking into account the cost of two piece hat/rotors alone easily pushes the cost well beyond this level.
While I'll be accused of being biased, I'd have to say that unless the savings are perhaps $500 the added funds spent on the aftermarket may make more sense. Obviously not everyone will feel the same.
Last edited by Todd TCE; Jun 12, 2009 at 05:01 PM. Reason: Noting not talking of 4-5 conversions requiring spindles, sorry.
True had i not come into opportunity with brembos, this would be considered, tc wheels are diffirent than sc hence the need to run a spacer or a wheel that would clear the caliper
