BWoody Front sway bar end links?
Old May 10, 2007 | 11:07 PM
biohazard's Avatar
Get low
i searched and couldnt find any answer to this, everyone uses the traction bars..... i need to replace my front endlinks and came across these but realized it said it was for the SS.... will the bwoody front sway bar end links fit a 2.2 base?
Old May 11, 2007 | 11:12 AM
SSdan's Avatar
I'm not sure, it might have something to do with the SS's having the 22mm front sway bar to begin with. Maybe the 2.2 one isn't as thick?
Old May 12, 2007 | 06:33 AM
big_stu's Avatar
I sent them an e-mail about this and they replied back saying that it would work. 2.2's may have a smaller bar, but the hole the end-link bolts thru is the same size on both. i'll be ordering these next week. I'll let you know how it turns out
Old May 12, 2007 | 03:23 PM
IonNinja's Avatar
I have those on my 2.2 Ion and they fit perfect...they were worth the buy too btw.
the 2.0 may have a bigger sway bar but that shouldn't effect the position of the links since it is the same suspension setup.
Old May 12, 2007 | 08:31 PM
biohazard's Avatar
Get low
ya i need some stronger , better quality ones, my factory ones held up good but the passenger side one finally decided it ditn like the airride and its creaking rlly loud when i turn right now lol so i figured to upgrade instead of factory parts, candy red anodizing is in mind too
Old May 14, 2007 | 06:56 AM
denniss's Avatar
The creaking is probably the bushings on the drive train cradle. its a common problem. When you put your new links on (they will fit), loosen the bushings up and grease them.
Dennis
Old May 14, 2007 | 07:33 AM
SS33's Avatar
I looked at picking up a set too, I am glad to hear that you think they are worth it Ion Ninja.
Old May 14, 2007 | 08:02 AM
alleycat58's Avatar
I'm getting a set for my b-day from my boyfriend, and biohazard, he ordered the anodized candy red so I can put pics up if you want. No idea when they'll be here, hopefully soon!!!!!!
Old May 14, 2007 | 08:06 PM
biohazard's Avatar
Get low
i think im ordering mine tonight its called starlight candy red or some sht... or starlight metallic i dont remember
Dennis
which bushings r these? what kinda grease
Old May 14, 2007 | 09:31 PM
denniss's Avatar
The rubber bushings under the U shaped brackets that the bar goes through on the cradle. I don't know what grease they recommend, but we just use white grease. When you remove the links you should be able to slide the sway bar one way enough to grease it and then slide the bar back into position. When the bushings get dry, they creak when the sway bar twists in them.
Dennis
Old May 14, 2007 | 09:32 PM
biohazard's Avatar
Get low
Dennis
i know what grease ur talking about but have never ha dto buy any so please exuse the ignorance, is it just called "white grease"?
Old May 14, 2007 | 09:52 PM
denniss's Avatar
White lithium grease. You will probably have to loosen the brackets on the bushings to be able to slide the sway bar over.
Dennis
Solaris99
28
Mar 15, 2017 01:22 PM
OrangeCoba
Oct 1, 2015 10:00 PM
SSLOW06
Oct 1, 2015 07:21 PM
DANRICKARD
Oct 1, 2015 12:08 AM
