Bwoody Traction Bars
Old Mar 14, 2007 | 07:54 PM
AROON02's Avatar
How Many Times Do I Need To Adjust Until Theres No More Wheel Hop?!
Old Mar 14, 2007 | 08:01 PM
calchr2's Avatar
not to be an ass, but i think untill you get it right and dont have wheel hop. do you have other traction mods?
Old Mar 14, 2007 | 08:20 PM
AROON02's Avatar
No, I Know Your Not Being An Ass, No Other Mods As Of Yet For Traction
Old Mar 15, 2007 | 11:53 PM
woody21001's Avatar
call tech help from mike. he can talk you thru it
thans
Last edited by JonyyB; Mar 17, 2007 at 12:57 AM. Reason: Contact info removed per site rules - no free advertising
Old Mar 16, 2007 | 12:05 AM
repoman's Avatar
what's the difference in the full race and the economy?
Old Mar 16, 2007 | 02:17 AM
PolishPauL's Avatar
^^^Yea do these add vibes or something? I dont think that this is good for a daily driver...
Old Mar 16, 2007 | 09:45 AM
woody21001's Avatar
they are great for daily drivers. the difference between full race and economy.the full race come with a full 2 year warrenty, the eco with a 90 day warrenty. full race rated for 24000lbs of force eco is 17000. that is still a lot more then your ever going to submit them too, but a lot of people go for the warrenty
Old Mar 16, 2007 | 09:47 AM
tim.t's Avatar
From: Yulee, Fl - home; Virginia Beach, Va - stationed
^^^That was my first thought when I read the question.
Old Mar 16, 2007 | 11:41 AM
PolishPauL's Avatar
These get rid of all your wheel hop? Than how come people go for mounts instead of this? There has to be something bad about this
Old Mar 16, 2007 | 11:47 AM
RuSSo-29's Avatar
I was wondering the same thing.
Old Mar 16, 2007 | 11:49 AM
PuSha050's Avatar
if u think theres something bad about bwoodys traction bars, go check out the reviews they have gotten on the redline forum or on srtforums ... the reason people get mounts is to take all the wasted movement out and get that power to the ground better. i seen my motor on a dyno with the hood open and the amount the motor moves is ABSOLUTELY disgusting
Old Mar 16, 2007 | 11:59 AM
aznpariah's Avatar
I just ordered the full race traction bars AND the full set of solid engine and tranny mounts. Like stated above, with the mounts you get vibration (especially with solid mounts) with the bars i don't think you'll get more vibration... i believe they brace your control arms so they don't hop as much. the mounts limit movement of the engine and trany. anyone know if there is a downfall to the bars i.e. too much limit in suspension/ steering travel... hopefully i get them next week and put them on then or the weekend after. weather sucks around here. Let me know how u adjusted it when u get everything worked out.
Old Mar 16, 2007 | 08:13 PM
woody21001's Avatar
the traction bars limit control arm deflection that is a major cause of wheel hop. the solid motor mounts minimizes engine movement further reducing wheel hop caused by the movement. the traction bars alone will almost eliminate all wheel hop in slightly modded cars, the solid mounts really help once you start reaching higher hp. for protection both are great, for wheel hop the bars are better, but i have seen in person the engine movement on these cars and also the amount of broken stock motor mounts we are collecting is unreal.check it out for yourself and decide.
Old Mar 17, 2007 | 12:44 AM
aznpariah's Avatar
yeah i'm going with both so i should be set... also got and ingalls etd (useless at the track) cant wait to get my stuff but bwoody has go get more bars in stock.... ahhhh....lol
Old Mar 17, 2007 | 01:12 AM
IonNinja's Avatar
if you've adjusted them several times and you still get wheel hop you probably should just invest in some other traction mods to go with them.
the bars alone did not get rid of my hop...alot of it but not all so I just ordered a set of tranny mount inserts to help take care of the rest of it.
Old Mar 17, 2007 | 11:26 PM
celicacobalt's Avatar
would these fit on an automatic 2.4 coupe?
Old Mar 18, 2007 | 01:18 AM
repoman's Avatar
they should, just give them a call to be for sure though
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
DANRICKARD
Oct 1, 2015 12:08 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
