clunk/thud in front suspension...
Old Dec 12, 2009 | 08:34 PM
02arcticz's Avatar
Hey everyone i was hoping someone could possibly relate to me my car is a 2005 ss/sc and it is completely stock. Im experiencing a clunk type of sound coming from the passanger side front suspension i was thinking its the strut possibly being blown? the car has 32,000 miles on it and still is covered by a warranty. but id like to have a heads up before going to the dealer any body experience something similar? its most noticable in the morning when cold but also when it warms up. any help is appretiated sorry for the length of the question.
Old Dec 12, 2009 | 08:45 PM
Bumpin Balt's Avatar
Control arm bushings or sway bar end links are both common problems with Cobalts. Your car is more than 3 years old, so your factory warranty is done. Do you have an extended warranty?
Old Dec 16, 2009 | 04:37 PM
wardzach2007's Avatar
Every single time I turn I hear a thud noise coming from my front. I'm lowered on Sportlines.
Could it be that I need new CV Joints?
Old Dec 17, 2009 | 01:40 AM
02arcticz's Avatar
Yes i have a extended warranty i got the car this past june. i also kinda get the thud when i turn the wheel left then back right real quick im not lowered though. Would anybody suggest any mods to make the car more solid or a better ride overall and possibly help this issue?
Old Dec 17, 2009 | 01:44 AM
car_guy_09's Avatar
I also get this noise once in awhile
Old Dec 17, 2009 | 01:51 AM
SSchargedSS's Avatar
moog sway bar endlinks
Old Dec 17, 2009 | 08:56 AM
My car does this also.
In for the fix!
Old Dec 17, 2009 | 10:27 AM
airliftguy's Avatar
It could be your upper strut mounts. Moog and another maker of these parts had quite a few failures. Mine did the same thing till I went to a spherical style upper mount.
Old Dec 17, 2009 | 10:30 AM
falke401's Avatar
Could also be your intermediate steering shaft.
Old Dec 17, 2009 | 10:32 AM
blk06ss/sc's Avatar
mine was struts
Old Dec 17, 2009 | 10:33 AM
cobaltfan10110's Avatar
I had the same type of noise too, turned out that the sway bar links and the bushing had gone bad. Replace those bad boys with something that can hold for more than a few years.
Old Dec 17, 2009 | 10:34 AM
MP Cobalt's Avatar
I get the noise also, I'm lowered on Progress springs.
Old Dec 17, 2009 | 02:25 PM
falke401's Avatar
I am just going to drive mine the way it is until major disaster strikes to find out exactly what the problem is. Im not going to replace the whole front end for a small clunk.
Old Dec 17, 2009 | 02:34 PM
06G85's Avatar
Not trying to thread crash, but I'm actually experiencing the SAME PROBLEM. It's more like when I go over speed bumps it sounds like maybe the strut is starting give out. It's like a squishy sound, but it's not the normal "gas movement" soudn we usually hear. It's squeaks too. I have about 33K miles
Old Dec 17, 2009 | 03:51 PM
02arcticz's Avatar
wow crappy front suspension lol, i guess i could just ride it out and see if something actually goes wrong. I understand winter is rough on a car but damn... thanks for all the replies and ill post up if i get any improvements from replacing things prolly wont be for a while though busy this time of year.
Old Dec 17, 2009 | 04:12 PM
Billig ss/sc's Avatar
I have a similar "clunk" sound, but mine is usually only when I first start the car up and it's only when I turn the wheel. It also happens more frequently in cold/rain. Idk wtf it is.
I have Megan Racing coilovers btw
Old Dec 17, 2009 | 04:14 PM
blk06ss/sc's Avatar
on my old sc it was the struts,replaced em and it stoped now on my t/c with the cold weather it does it until i drive it then it goes away as if the strust are frozen ( also only on bumps )
Old Dec 17, 2009 | 07:22 PM
02arcticz's Avatar
yeah mine is hard to replicate after the car warms up, or is driven a good distance but it sure is annoying to have a fairly new car with clunks and thuds.
Old Dec 17, 2009 | 11:34 PM
joe118969's Avatar
Get use to it, I've had it on a lift, and found the lower control bushings were cracked, replaced them with some oem ones, replaced sway bar mount bushings, struts, and strut mounts. It will come back...
Old Dec 17, 2009 | 11:37 PM
BlackJackSS's Avatar
mine was stabilizer bar bushings. end links are another common problem.
Old Dec 18, 2009 | 02:44 AM
BlkWdoSS's Avatar
Mine has been clunking for a while, everything I have read goes back to endlinks so I am getting ready to replace them. Im going with a set of these:
http://www.overkillengineeringmotors...wbarendli.html
I feel the ball joint in the stocker end links could be most if not all of the problem
l8r,
PD
Old Dec 18, 2009 | 10:34 AM
xxxxsh4d0wxxxx's Avatar
I used to have a clunking if I would go under like 4mph and turn the wheel I would get a "clunk clunk clunk" type noise..
Went away for now, I still have no clue what it was/is.
I've been on Sportlines for almost a year.
Old Dec 18, 2009 | 03:56 PM
dspeed123's Avatar
My car does this too. Its irritating because I already changed the control arm bushings with OTTP ones and then went Moog sway bar links. I think my next step is going to be the upper strut mounts and struts. My car has 60,000 though so I figure its about do for some struts since it is a Chevy. Probably the reason I've owned imports since 2000.
Old Dec 18, 2009 | 04:00 PM
miked5426's Avatar
on my 2005, the first thing that went was the SWAY BAR BUSHING. jack up the car and take a peak. if u see space in the bushing area, then you know. mine was rather obvious.
i agree with this. i did the exact things u did, still have a clunk. mine sound more like under the steering wheel somewhere....maybe in the steering itself
Old Dec 18, 2009 | 07:30 PM
02arcticz's Avatar
Glad everyone can share all the similar problems together. Kinda sad that my 91 accord that the cobalt replaced as my dd had a million less issues, o well live and learn.
