coil bind?
dang I've already bought eibach lol.. I heard from powell that they do but didn't think they were that bad but then saw a few posts about them. are the pro kit springs as bad? there's no drop in the front and only half an inch in the back with the pro kit on an SS TC
ProKit springs have some of the 'softer' parts of the spring covered in rubber so they can stackup and bind under heavy load (like hard cornering) and allow the stiffer part of the spring to work as designed. In some cases, for progressive springs, coil-bind is the norm -- it's designed to work that way...
Scott
I have ProKit springs and they aren't as bad as demonstrated.
Scott
Scott
Scott
Scott
Scott
Scott
I would postulate that if those coils always stay bound, it's not so bad. However, if they unbind and bind during driving, the spring rate will be inconsistent as it transitions. Is there any load on the car in this pic? That looks excessive, but the fact that they have the sleeves all the way down there is not a good sign.
I'm not advocating coil bind. But it is a fact of life for some springs, and anyone who buys those springs should expect coil bind to exist... Some springs are worse than others. The springs pictured are horrendous!
Scott
Granted. I simply point out that allowing coil bind is one way of configuring springs to have both soft and hard sections (the softer section compresses and eventually binds and that forces the stiffer section to do its job).
Scotyt
Scotyt
Obviously, some vendors (apparently) deal with 'drop' by weakening the springs and thereby causing excessive (early) bind. I can't prove any of this, it's just my suspicion based on what I'm seeing (the photos).
I might also add that 'cheaply' built, improperly heat treated springs, might quickly 'sack' (I'm not sure about the spelling) -- in other words, the metal weakens quickly with usage and loses its initial strength, thereby collapsing upon itself.
It's also worth noting that springs that coil bind regularly will frequently 'grow' larger in diameter as a result of binding (they are kind of squished out).
Regardless, the end result is what is seen in the photos.
Scott
do you guys think that having the springs in the rear upside down is affecting anything? My rear seems super soft compared to the front, even with the rear bind. the front bind is HIDEOUS.
I need to cut my front bump stops! (how much should i?)
Scott
Your bump stop is there for a reason. It's keeping you from paying big bucks fixing broken **** due to crap coils. Don't cut it. It's far better to pay for better springs than it is to pay for repairs and then pay for better springs.
