Coilover install
Old Mar 13, 2011 | 11:29 AM
mongorat427's Avatar
Coilover install
OK Im working on the front suspension. Just installed D2 Coilovers and Rebel Autowerks Brace Coilovers took about an hour and a half an brace a half hour. Now I need to do the final adjusting and put my splitter on. Next Ill start on the rear. Finally getting some good weather
Old Mar 13, 2011 | 12:08 PM
PsychoCam's Avatar
looking good Jeff! what is next on the list to install?
chrisjaldin's Avatar
pretty nice install. good photos
Old Mar 13, 2011 | 12:10 PM
royce777's Avatar
nicee looks good!!!
Old Mar 13, 2011 | 12:38 PM
Im going to do the air splitter next. After that rear coilovers and Hardcore bar.
Old Mar 13, 2011 | 12:46 PM
conerboner's Avatar
I've never seen the brace before. link please. Looks good!
Old Mar 13, 2011 | 12:53 PM
EXsoccer1921's Avatar
got any pictures of the splitter?
Old Mar 13, 2011 | 12:55 PM
Twin Sub Frame Bar - $129.99 : Rebel Auto Worxs.ca
Old Mar 13, 2011 | 12:57 PM
D2 Racing NA - Products - RS Coilovers
Old Mar 13, 2011 | 01:31 PM
crazywhiteboy89's Avatar
how hard was the bar to install??
Old Mar 13, 2011 | 02:39 PM
Very easy the main thing I did was replace the bolts one at a time and threaded them so they barely came through except for one which I threaded all the way in. Then I went to the opposite side and held the bar up on that bolt and screwed the others in.
Old Mar 13, 2011 | 10:00 PM
so u have to remove stock bolts?
Old Mar 13, 2011 | 11:41 PM
Yes The bolts provided are longer and thread through the stock threads and the bar is held on by 4 Nylock nuts
Old Mar 13, 2011 | 11:45 PM
Garret's Avatar
im glad you showed good install pics,
but I wanna see the cars stance haha
and your splitter once you install
Old Mar 16, 2011 | 11:32 AM
Update
Old Mar 17, 2011 | 04:25 PM
Adjusted the rear shocks today. They have 36 adjustment Dampening so I set them right at 18 as a starting point. Ride feeds good so far. Im going to set the fronts the same way.
Old Mar 17, 2011 | 04:29 PM
Ting-ting's Avatar
my stances are horid in the rear idk why i still having to mess with them
Old Mar 17, 2011 | 04:33 PM
BartSS's Avatar
mine too man im just gonna crank those bitches like all the way
Old Mar 17, 2011 | 04:42 PM
Ting-ting's Avatar
like mine bottomed out so bad that it broke my bump stop plastic top...i raised it and still doing same **** idk whats up
Old Mar 17, 2011 | 06:02 PM
Sounds like the shocks arnt adjusted right. How do those adjust ?
Old Mar 17, 2011 | 06:05 PM
BooSSted's Avatar
I guess now we know why you're selling them!
Old Mar 17, 2011 | 06:21 PM
Garret's Avatar
Looks good mongo
Old Mar 17, 2011 | 06:31 PM
Ting-ting's Avatar
They adjust on the spring and on the shock in the rear
Old Mar 17, 2011 | 06:38 PM
I took my shock adjustment all the way in 36 clicks and backed them out 18 clicks which is halfway as a starting point. It took a couple adjustments on the springs to get them where I wanted them
Old Mar 17, 2011 | 06:52 PM
08ssedan's Avatar
Looks reaaaal good!
